Special thankyou's to Gary, Mathew and Mike...
& Finally....
many thanks to Mike.
During the time that Mathew was oop north, we arranged to pop into see Mike for a couple of days, during which time Mathew perfomed some surgery on his A3008 Keymatic de luxe.
First off though, some pics of other machines:
a new acquisition of Mikes - Hotpoint 17351 dryer....
the 3224 keymatic, waiting for some final tinkering and a water test, now fully equipped with an intact door gasket!
and next door to Hoover UK's first dryer - the model 3020...
Having detached the upper support springs, Mike pushes down on the outer drum for Mathew to undo the top backplate bolts...
and, after a bit of persuasion, the backplate is split from the outer drum for probably the first time in 30 years...
Removal of the backplate also revealed the curse of Hoover outer tubs - namely rust spots developing around the motor support welds.
Another machine, which has recently been dealt with, was found to have the same issue but on a worse scale, with gentle rubbing with fingers producing actual holes...
