Speed Queen AFN50R question
There are screws at the top back of the control panel that allow you to remove the top of the control panel. I went in there when I adjusted the water level. Maybe you will find something at the bottom of the control panel area. Maybe there are screws on the back that hold the top down. Sorry I don't know more.
Imperials
The imperial machines are quite different for cabinet access so I don't think I can comment here. Someone will surly have the information you seek.
Malcolm
Service Manual
I wonder if anyone has the official service manual for these models. Would love a copy!
Malcolm
Removing the top of a SQ FL Washer
You first remove the lower front, then remove the upper front panel [ two screws at the bottom of both front panels ] and then you remove two more 5/16" hex head screws and the top panel lifts at the front, hope this helps, John
