SQ FRONT LOAD WASHER
Hi David, glad the washer is getting fixed, Some Thoughts.
The use of HE or Non-HE detergents will not affect seal-bearing life on ANY FL washer.
On FL washers bearings only fail 99 44/100% of the time because the main shaft water seal allows moisture to get past the seal and ruin the bearings. The life of bearings in FL washers has nothing to due with a tilted or non-tilted tub, size of the bearings etc.
The thing that will most often ruin the seal in a FL washer is a hard mineral build-up from minerals in the seal area [ this is primarily caused by using too little detergent, cheap detergent, excessive rinsing especially in hard water areas ] Detergents have important lubricating properties that protect washer parts [ like water seals ] and if things are rinsed too much it is hard on ANY washing machine ever built.
Main water seals can also be affected by heavy build ups of molds and excessive use of fabric softener [ if fabric softeners are used in an automatic washer it is imperative when clothing is being washed to use plenty of detergent and hottest water possible ]. Other reasons for moldy build-ups are too little detergent, too cool wash temperatures, and a lack of chlorine bleach use.
David I would ask to see the main trunnion assembly after they fix your washer, this is the huge cast aluminum part that the bearings and water seal are pressed into. By looking at this part you maybe able to gain an idea why the water seal failed. It is highly likely that usage situations at your house caused this early seal failure and if not addressed you may have the same problem again in a few years.
This washer is designed to be repaired in the home and if the repair company wants to do it in the shop the transportation should be at their expense. The main exception to this is if there is insufficient room to perform this repair in your home. SQ FL washers are the easiest FL washers that we have ever installed main bearings in. It takes one person less than 2 hours to complete the repair and the retail cost should be less than $500 in our experience as a SQ authorized servicing dealer.
Hopefully your washer will be back and running soon, at your usage level you should be able to keep this washer running for a decade or longer. I do highly endorse the idea that you have some type of back-up washer, but when you consider how much this washer has already saved you on water, detergent, and energy costs from heating water and drying the clothing it would make no sense to go back to a conventional TL washer.
