SPEED QUEEN SOLID TUB WASHER UP AND RUNNING!
rollermatic
Oct 10, 2009
2,068
columbus and milford ohio
haven't done a thread in a while so here goes! got my speed queen washer back together this past march, bought it back in late 2010! just now posting it! been a busy summer!
here it is in the jeep after getting it that day from indianapolis. i still had a soft top on my car back then and remember what a cold day it was!
pic from back of machine
showing pump and motor and rusty bottom when i first got it.
a few coats of rusty metal primer did wonders to this area! and all 3 belts were fine and able to be used! at least they are fine now! hopefully if they break i can find more!
close up view
of drain pump.
this pump is fine and has no leaks although i did have to get a pump gasket for it. luckily i found the gasket at partselect.com. it was one of the few parts they still carried for this washer!
pump is
out.
don't like the look of that output port. pretty chewed! it will eventually erode away to the point where a hose will not fit on.
gave it about 10 coats of primer, inside and out! and i'm only using this washer for fun about once a month.
