Speed Queen washer AWN311 water level
adjusted water level ... ...
I adjusted mine to fill up to the top row of holes and slightly above that. Works great, LOVE this machine !! I think its the only top loader that has the full, traditional long stroke unlike all the others on the market.
How high do you recommend?
JeffG
Thanks for posting that link, I am definitely going to adjust my water level now. Would you recommend to the top line of straight holes, or to the "zig/zag" holes all the way at the top. I always wash large loads, very rarely do I wash smaller loads.
mtn1584
I am going to adjust mine tomorrow to the bottom of the top zigzag holes...I hope this makes sense or to where I show a pic of the tub filled to the holes in #378901
I've had no problem with filling to the zig-zag holes, for almost all loads. Be careful when washing large bulky items like mattress pads, pillows etc. A lot of water can slosh around and possibly over the outer tub.
The Adjustment has been made
I made the adjustment last night, my machine now fills to the top row of straight holes, and I also "tricked" the lid switch by rolling up the Sunday comics into a nice rectangle and pushing the lid switch down. Thanks for all your help.
So - still kicking myself...
I had an older version of these Speed Queen machines (Branded Kleenmaid here in Aus.) and stupidly got rid of it when I moved last... Anyhow - now have a maytag centennial... Been a good machine - but it's just not the same...
However - does anyone know if I can tinker with the water level switch on the Maytag? Unlike my old speed queen - it's not an infinite water level switch - the maytag has a 4 stage switch mechanism... Do these work in the same manner? Does anyone know if I can adjust the Super Plus (highest level) setting? It just doesn't quite have enough water for my liking - and as JeffG states - those extra couple of inches - makes a whole lotta difference on a full load... Any help would be appreciated...
Even if someone has the service manual for the newer maytag/whirlpools they could email to me??
Thanks Kindly folks!
Streakers.
Hi Streakers,
On those Whirltags, its a fixed position pressure switch. Fully enclosed in a plastic case that may or may not dissasemble.
I've never tried to pull one apart, but the easiest way could be to extend the length of the pressure tube.
If you try and pull it apart, my experience has been that whirlpool spares are very expensive and hard to come buy. I had to replace the lid switch on Mums whirlpool and it was going to cost $230 for the part and take 5 weeks to arrive from the US.
Just something to be aware of if you try to remove the plastic case off the pressure switch.
Cheers
Nathan
Wow - that sounds pretty scary!
Thanks Nathan - in that case - perhaps I should just hold off until I'm ready to replace this one with another Speed Queen... I don't want to do any damage and have it cost me any cash.
So - have you seen the internals of one of these new Whirltags? I've not ever had the chance to pull it apart and see it. And in saying that - it doesn't appear to be as easy as the S/Queens to get into.
By the way - you have a pretty impressive collection. Did you manage to pick up most of yours in Brisbane? Ever going to do a 'wash-in' like our fellow collectors in the US?? Cheers Steve.
I adjusted the water level switch today...it was very easy to do and now its at the very top row of holes. Now I wont have to stick around and wait for it to fill to get it to the level I want it to be.
I have the AWS45NW that I was fortunate to find second hand a few years ago. Love that washer! It sits patiently in my workshop waiting for the day my wife's plastic GE finally breaks. She loves the GE, I don't! Any ideas on how I can sabotage it? I do run the Speed Queen about once a month, works flawlessly, and even SOUNDS solid! I'm happy for anyone who buys Speed Queen
Take good care of that washer, it's the last SQ TL that included a warm water rinse option. If we could find a 45NW or 75NW in new condition we'd gladly trade in our 76NW.
Jeff, couldn't you buy a tempering valve to raise the cold water temp up to around 100F? Granted, that would change the wash temps to hot, medium, and warm, but it would also have all warm rinses... :)
Jamie, we installed 2 Y-adapters at the hot water tap and cold water inlet. The adapters have individual shutoff valves on each side, so temps are totally adjustable. But I've heard a lot of horror stories about stress failures with these adapters, even though they're brass, and I'd much prefer just having a warm water rinse option via the washer's control panel, without the extra plumbing.
Perhaps swapping in a replacement temp switch for an older model that does have a warm rinse selection will solve the problem. Or add a toggleswitch into the wiring harness.
That first idea sounds great. What part# do we order? We'll call Alliance on Monday. Thanks!!
Water Level Adjustment/Temperature Control Switch
Hey Mike, glad to hear that you got your water level adjusted to the level you like! Our washer on the extra large setting goes to the bottom of the zig zag holes in the tub. For me it's not really worth messing with since it does cover all the loads I've done in the machine. But now I know how to do it if I ever decide to raise it a bit. One thing you should know, I overfilled the washer one day up past the plastic inner ring then I heard the water running over inside the machine. It was just a quarter of the way up where the plastic ring meets the stainless steel. So just a word of caution, you don't want to overfill the machine - I learned the hard way. Luckily it didn't flood all over the basement floor and I just let it dry out naturally and it's been fine ever since. I know, it was a stupid mistake.
Now Jeff, the temperature control switch has got my curiosity. Do you think the extra position with a warm rinse might have an extra spade lug to attach a wire to it? I'm sure you'll have to relabel the control panel to accommodate this. But, I just thought - how much would a replacement control panel cost? I'll have to go online to try to find out if it can be purchased! That way the labeling for a warm rinse will be right there for your choosing.
Just my .02
Mike L.
Mike, unfortunately the AWS75 graphics panel (which includes four wash/rinse temperature options) is NLA from Speed Queen, so our plan to replace the temp switch is on hold for now. I'm hoping we eventually find a panel, either a pull or NOS.
We did find pricing for it on two different sites (SQ's part# is 38830W, in case that helps you), one was $28 and the other $25, but neither company had any in stock and they can't order them from SQ.
As for the wiring, I assume the 4-position switch would have four terminals instead of three.
leaning towards the Queen
Just looked at some SQ's today @ AAA Appliance in St.Peters,MO. This site got me interested in 'em for replacement of our '96 90 series DD Kenmore.(which may never die!) The higher water level info VERY germaine! Looking at the service manual,I'm a little bummed that SQ uses belt slippage instead of a slippage(fluid) clutch for spin accel. From vids on youtube,the SQ's appear to wash well AND make near woo-woo sounds at times. I'm intrigued & impressed overall.
doesn't the older maytags also use belt slippage in the
All of the *true* 2 belt Maytags from 1956-2006 slipped the belt in place of a clutch during the beginning of the spin cycle.
Queen Absolved!
I feel much better knowing the classic 'tags used belt slippage for spin ramp up. Thanks for the input. Glad this site exists for us washing 'machine heads'! Fun/technical/& save money/aggravation avoiding the junk while touting the few good machines available.
Bit of a snag...
Went back to appliance store to pick a water filter ($63.99!)I'd ordered for our GE(came w/house)'side by each' fridge. Looked in the SQ tub. MAN,they sure don't give a damn how their stainless panels come together! Instead of butting-up-to on the main side tub seam,SQ overlaps with a fairly sharp edge remaining. The same edge that-with the clockwise spin-will be 'face fronting' your clothes. Could've at least overlapped to the 'rear'of spin direction. The side tub panels & lower tub panels don't come together smoothly either. ALL have some evidence of grinding/sanding to make the merges maybe less 'edgy'. I think I'd still buy this machine,but a smoother tub would impress me & SHOULD be 'in there'! JMO
The tub seams on our SQ are as smooth as glass. Also, their tubs have a lifetime warranty, so I'd be very surprised if they slacked off with their quality control.
