Speed Queen
Speed Queen Rules
I bought a new Speed Queen top load washer about a month ago, I am amazed how much cleaner my clothes come out compaird to the way my old Kenmore cleaned them. I recommend a Speed Queen to anybody looking for a new washer.
My set is about 5 Years Old now.
I bought that model washer and the TOL dryer. I think it has been a good machine. I wish the spray-rinse was more thorough----and it is if there is a really big load of clothes. Otherwise most of the water just drops to the bottom like a modern Norge. It does have a full "deep-rinse" for each cycle---thank Heavens! Don't care too much for the "leaning tub" issue during agitation. Mine leans pretty far towards "2" O'Clock.
I found my (gas) dryer to be a bit slow! Usually my gas dryers have been pretty fast. I took it out of service early on and she sits and bides her time these days.Very low mileage. My 1969 Whirlpool Gas Dryer is the best dryer I have EVER owned and it got put back to work! Even my '53 Filtramatic is faster!
I got an identical set for the "office".
Strangely, since we use a lot of (single-bed size) sheets I discovered the machines have a habit of twisting everything up into knots when doing a full-load of them!
Not since the Old Rustinghouse slant-fronts and small-tub Frigidaires have I seen such a mess! The last issue I would have expected from these machines!If we add a mixture of towels and sheets the problem stops! That washer tub leans to the 6 O'Clock position. My friends in Atlanta have a set and that washer also leans towards 6 O'Clock. My Israeli friends here in Roanoke have a set and that washer leans to 4 O'Clock.
Nonetheless, I am quick to reccommend the brand. Everyone I know with them is pleased with them.
My pair is seven years old!
I have the AWN 542 and matching electric dryer!
Use and abuse them! They're work horses!
Yes the tub leans during agitation, so what?
The tubs always re sets itself for the spin and NEVER EVER goes out of balance.
Best of luck to you.
Mike
Question: Is the tub supposed to index during agitation? I also noticed is doesn't seem to do so on the "Delicate" cycle.
I've had mine since mid-April, and I'll say it again; after having had to go back to a T/L after owning F/L's since 2000 (I couldn't afford a SQ F/L) it really IS a swell machine, and I'm glad I bought it; from what I've seen on these posts, and on YouTube, the HE T/L's didn't impress me all that much. I'm still having difficulty getting used to it running a complete cycle in a half-hour, or so! (lol)
No worries
The indexing will eventually stop when the factory applied lubricant wears off the brake shoes. It won't index on the deliate cycle at this point because the agitation stroke isn't as fast.
No worries it's working as designed.
Mike
Mu tub leans to the right in agitation. Why does it do that? Also i know the softener dispenser comes off to clean it but how does the two parts of the dispenser disassemble?
I usually just take the softener dispenser and soak in a a pail of hot, sudsy water then use a tooth brush to scrub it out. Mine just pulls apart to reveal a tiny cup inside. I ended-up having to take a die-stamp and widen the holes at the lower part of the barrel (agitator) to keep softener from plugging them up.
Even after about five years, the tub in mine continues to index slightly, however, that doesn't really bother me as much as tipping-over during agitation. Seems as though I heard somewhere it had to do with a torque issue.
there something about the torque of the motor that causes the tub to lean.....SQ doesn't see it as an issue, so nothing to correct it.....I added foam inside the cabinet and front panel to keep it more centered....and even more quieter.....
the dispenser should twist apart to clean.....
mine is a lot older, so a few changes I did was, drilling out the water valves for a 50/50 mix, clothes pin for the lid switch, and sealed off the back of the fill flume so all the water falls into the tub....my agitator is solid versus the power flex of the newer models.....
did you know a Dual Action agitator from a GE Profile will fit the SQ drive bell....
Didnt know that about the agitator from the ge fit the sq. My fill flum fill completely in the tub and angled to the right to hit the clothes during spin. Next wash i do ill video the spin spray.
What kind of foam did u use to level out the tub and how u secure it in place?
you have to trace back through some threads of how they attached these.....but basically, you have to find an old agitator, and cut off the vanes and such, as to have something to attach the new agitator to......
if you follow this link.....further down, you will find a solid vane agitator.....and our own DanManTn did some videos of the two in action...
the foam I used was that egg crate type used for beds, cut to fit and glued in place....
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?30970
After 3 months
all is well with our SQ AWN432. Never enjoyed washing clothes as much as I do with
this model. Cycles are done within 30 minuites. Will get the matching dryer once the Whirlpool goes.
