SQ water usage
supersurgilator
Jun 23, 2007
453
Indiana
For those of you that have a newer SQ washer, any idea how much water it uses for a large load? I know the specs say 27 gallons or something close to it, but I'm assuming thats for the eco cycle. The only thing I have found was a manual for one of the new Australian models and it states 26.2 gallons for the eco cycle and
46.5 gallons in the regular cycle. I'm assuming it would be about the same, even although 46.5 sounds like a bit much to me.
Given the tub size and such, 46.5 gallons sounds about right for a full load.  They're being purposely deceptive with the volume of water to appease the tree huggers.  Face reality, it ain't gonna be water wise.  It's a top loader that fills with water.  Personally, no one in their right mind should use that "normal" (eco) cycle if they just have to have a traditional top loader.   My Lady Shredmore used 46 - 48 gallons for a typical normal cycle.
The medium water level which fills nearly to the top takes in 17 gallons according to our water meter. I'm guessing the high water level takes in 21 gallons or so. My rough calculation came in at 43 gallons per cycle so 46.5 doesn't surprise me. Our last water bill was up to 4,800 gallons from 4,000 the months prior to the new SQ. it'll probably drop some now that I've washed every possible thing I could find in the house Hahahaha.
Here in Oz SQ washers are rated 70 liters per complete fill, which is equivalent to 18.4 gallons.
I don't understand why they don't re-introduce the suds saver function on top loaders. I bet that, when used correctly, it would make these machines more effective and efficient than the highest rated HE front loaders. I used to have a washer with that function and used it frequently without finding it inconvenient or a chore.
By rights, twin tubs, if used as originally designed, are most certainly more efficient and effective than all other types of washers on the market; they just require a bit more hands on involvement. Twin tubs are certainly a lot quicker than most HE machines. I would think that, apart from wearing a loin cloth, twin tubs would be the perfect choice for all those eco warriors who are so worried about how much water washing machines use.[this post was last edited: 5/15/2015-21:51]
Jerrod
Just a few dollars. The last water bill was about $62 this one was $70 The jump in sewer charges is more then the jump in water. 5 dollars of that increase was the sewer.
$17.75 of that is trash collection, $7 of it is for storm water hookup (for the sump pump) and then there's some other surcharges added into that mix too.
"Could you please tell us why you aren't the Minister for Environment?"
Considering that most politicians have no formal training or experience in their appointed portfolios, it wouldn't be to the nation's detriment if I or anyone else had a go at it. Unfortunately I don't possess many of skills and qualities that are required of career politicians. In my chosen career I have to be skilled, knowledgeable, truthful, professional and always act with integrity, compassion and for the benefit of others. That is why I would never qualify to become Minister for the Environment. How about you?
Suds save machines
Do a good job at reducing water usage in a top load machine when used correctly.
My mother had a solid tub Simpson Fluid drive (4 speed programmed - Leon has one) that, if memory serves correctly, used 13 Imp gallons per fill, so 26 gallons per wash cycle. Capacity was noted at 10lb
90% of the wash water could be reused if your tub was set up correctly, with heavy soils settling to the bottom.
Mum used hers like this, topping up the detergent with another 1/3 dose:
Whites - hot wash
Suds save
Coloureds - warm wash
sheets - hot wash
suds save
sheets - warm wash
Towels -warm
suds save
Dads work clothes (builder) - warm wash
Over the 6 loads of washing it was possible to reduce water usage from around 700 litres to around 540 litres. 90 litres is still a significant amount of water to wash 4.5kg/10lb of washing, but puts it on-par with most front load machines from the 1980's.
So I was thinking, the 17 gallon tub must be the one used on the coin op machines? I have a brochure from 2004 when the coin op machines was listed as 2.5 cu. ft and the water usage was 33.5 gallons per load. I think it said the tub held 15 or 16 gallons? That seems about right with the ratings of the newer ones
Anyone who knows anything about anything other than subterfuge is immediately disqualified as minister of anything anywhere. (Is that the most 'anys' you've ever seen in one sentence?)
Twinnys: I'm no eco-nazi but I'd just as soon use no more resources than it takes to get the job done. So yeah I run a twinny. I can do my entire laundry with something on the order of 15 gallons including a fill rinse. And if you drank the final rinse/spin water it wouldn't hurt you. No automatic ever invented can do that. So any eco-nazi using an automatic is not only a loudmouth phony but a lazy one to boot. "YOU should save water but *I* can't be bothered."
"no more resources than it takes"
Well, you forget human work is a resource, too. And saying that someone isn't concerned about the enviroment because he&#92she is just not willing to spend 1-2 full working hours on doing 2 loads of laundry and rather uses 5 gallons more is just plain wrong. Sorry, but as much as I'm concerned about saveing, there is no practical way for me and everybody that lives with me to do laundry in a that manual way. It's not lazy. But for 6 people, I'd like to see you doing your laundry in a twinny. It might work for you. But the idea of an HE AUTOMATIC laundry system is to save you work time and still do the job efficent.
Oh, and, how much laundry are you doing with 15gal of water?
On suds saver systems: I guess, they are usable. But they produce more work than saveings in my opinion for today standards.
First: Soil today is different than 30 years ago. 30 years ago, laundry was more likely to be heavy soiled with stuff like mudd, dirt or other "heavy" substances. Today, it usualy is sweat, dust etc. While dirt, sand and so on settle down in a laundry tub quite fast, sweat residues will basicly always stay in solution. So your wash water won't be that self cleaning.
Further, as far as I understand the set up, one had to move the drain hose after the wash drain from the laundry tub into a drain for the rinse. Then you had to move it back to the suds for the next wash and then back to the drain again. Quite a lot of timing, isn't it.
Last but not least, I know that at least half of the persons I know do one load laundry. They don't pile until the weekend. If there is a load, it's washed right away. Suds saveing is imposdible in that way.
Having owned a top loader with suds save function I can personally attest to it not being of any significant inconvenience or labor intensity. I never considered plugging the laundry tub, pressing a button and turning a dial, labor intensive. Admittedly it did add a few more moments to the laundry process, but, theoretically (I've not had the chance to test this) you could easily do that and still SMS or watch porn on your I-phone at the same time - so no harm done. There was no need to fiddle with hoses (unless it was my own), the machine and laundry tub were specifically designed to make saving suds incredibly easy and convenient.
Reusing suds during the laundry process was effective and common practice for centuries. It works exceedingly well if done correctly, i.e. proper rinsing is absolutely essential. As far as I know laundry suds were never self-cleaning. Their purpose is to clean the clothes that one puts in them. That is why chemicals are added to dissolve and suspend the stuff that is meant to get washed out. Then follows the rinse to take it all away and down the drain, leaving clothes clean and fresh. However, I am just an old fossil, set in my ways, what would I know?
Has dirt really changed? Is there now modern dirt and old-fashioned dirt? Are modern machines specifically designed to deal with 'modern' dirt? What would happen if I put old-fashioned 30 year old dirt into a modern washer? Is this a trick?[this post was last edited: 5/17/2015-11:21]
You got me wrong...
... and got me wrong pictures in my head.
First: Dirt it self hasn't changed. But the soiling of clothing has. My father still wears his work socks, shirts etc. at least 3 days. I wear my shirts one day. While 30 years ago a bigger percentage in the EU and the US worked in "dirty" jobs (farming etc.) with those different soils, that amount reduced until today. So the average soiling has indeed changed by today.
Self-cleaning suds: Whirlpool displayed it so nicely. As your wash water sits in the tub being saved, heavy soil particles settle to the bottom, lighter soils float on top of the suds. As the suds are returned, those lighter soils as well as the heavier once stayed in the tub. The wash water cleaned it self to a certain degree.
With todays soiling, that process is less effective.
But on the other hand, todays laundry is generally less heavy soiled and thus suds might be reusable still.
Laborintensity: So, just to get it right: You plug your laundry tub, place the drain hose into it, start the first cycle. The washer washes, drains and then spins, draining into your saveing area aka laundry tub. The rinse starts.
Now, you want to drain the rinse water away and not into your saved suds. So, while that 5-10 minute window, you'd have to be at your washer in time to move the drain hose out of the tub so the water drains away. After another 5-10 minutes, your laundry would be done. You'd move it to the dryer, fill the washer with the next load. Now you'd place the hose back into your saved suds and let them be pumped back in. You'd unplug the tub as you don't want to save the suds again and let the washer finish it's cycle.
So, you'd need one additional visit to your washer that has to happen in a 10 minute window. You'd have to move the drainhose 3 times within that procedure. For me, that looks like work. Not much, but enough to cause inconvenence. Especially if laundry us situated in areas where a laundry tub might be more common to find like a basement or a garage.
Suds saving wouldn't work for me with the way I laundry... but I could imagine reusing the rinse water for the wash, as some washers automatically did (Fagor and Electrolux, for example).
A twin tub would be fun to use but too labor intensive in the long run - at least for me.
Suds saver washers had two drain hoses.  One for the wash drain (if selected to "save" suds and the hose used to drain the rinse water.  If "save" wasn't selected, then the hose used for rinse water was also used by wash water.  The suds save hose was selected by a diverter valve.  Also, one shouldn't have added the next load of laundry until after the sudsy water was returned for the subsequent load.  Otherwise, too harsh on clothing because usually the agitator agitated while suds were being returned.
If Speed Queen offered a ToL model with suds save function I would snap it up in a heartbeat.
Bob described the suds save set-up correctly. One hose drains the sudsy water, to be reused, into the holding tub and another drain hose drains the rinse water, via a diverting outlet, down the drain. When the cycle has completed clean clothes are removed, the program dial is turned to suds-return, which activates the agitator and reverse pump and the sudsy water is siphoned via the dedicated hose back into the empty machine. Once the machine is full some more detergent, maybe hot/warm water and a new load of clothes are added and the laundry process continues. With that next load one would unselect 'suds save' to allow 'all' the water to go down the drain. Top loaders use different amounts of water depending on the size of a wash load. Sometimes only half of the saved suds were needed for a smaller load and the suds that still remained in the tub could then be used for a third load. If needed, one could always add fresh water and more detergent.
When one becomes familiar with this facility it is incredibly easy to use and very effective. Anyway, nobody in my house ever got Cooties from saving suds and our clothes were as clean and fresh as a newborn.
Of course if one suffers from some form of ADD suds saving might present an insurmountable challenge; it does require a degree of pre-planning, not just the common laundry dump and run. Perhaps more utility stars stickers, colored, flashing lights and tinkly tunes are what is really needed to keep consumers focused and happy.[this post was last edited: 5/17/2015-23:05]
Inventors step forward
Someone needs to invent a standalone unit that would convert and washing machine into a suds saving unit. Amazed it hasn't happened already.
Malcolm
"you forget human work is a resource"
No, I am retired, human work is a SURPLUS. I have LOTS of it. Whereas money for supplies and utilities is a paucity, to be supplanted by surplus time whenever possible.
Yeah it just happens to save the whales. As if 5 gallons weren't a teaspoon to a whale. Or as if whales didn't do just fine for a half million years before I was born. Besides, what did they ever do for me?
Not only is the twin the least resource-intensive way for me to meet my laundry obligation, it also escapes being confiscated as contraband in my retirement poorhouse.
You launder for SIX people? Then our perspectives are going to differ, now aren't they?
