Staber
control panel
No , On the machines that we had there was a board that controlled the then 2 speed spin and temp. Then it connected with the motor controller board.. They did away with the next model year and the machines then only had 1 spin speed. The models we had had a 1200 spin and a 750 spin.. The 1200 beat the machine to death!
Am wondering if building anything larger than 5kg (11lbs) just causes more problems than it's worth with top loading H-axis washers. IIRC Miele and others stop at that range, and there seems to be no one in any rush to develop any thing along the uber-sized units simliar to Staber.
There are commercial H-axis washers, but they mainly load from the front, and, IIRC don't offer super high rpm final extraction speeds.
Usually the drum is 3 to 6 litres more than a standard 5kg machine.
Candy as an example says that the drums are 56 litres and hold 7Kg of laundry but I can't remember the model number now.
Brandt
have a Family TLHA model...which reaches 7,5 Kg but is not the usual 40cm wide but 45!
My Ignis is said to be a 5Kg capacity but honestly I can fit in it more than my 5Kg Whirlpool...so it could now be called quitely a 6,5Kg capacity washer
