appnut Well-known member Platinum Member Joined May 20, 2001 Messages 19,666 Location TX Feb 16, 2022 #21 Cold tap.
powerfin64 Well-known member Joined Oct 27, 2003 Messages 600 Location Yakima, Washington Feb 16, 2022 #22 cold water tap. I have the same set as Bob.
R roscoe62 Well-known member Joined Dec 9, 2010 Messages 327 Location Canada Feb 19, 2022 #23 Appnut / Powerfin64 One more question regarding the water fill, does it have a water restrictor in it, like my older LG washer had,if so did you remove it or no? Thanks in advance
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,894 Location TX, U.S. of A. Feb 19, 2022 #24 Seems a bad idea to remove a flow restrictor from a steam dryer's inlet valve. Dryers shouldn't quite exactly "fill" with a lot of water.
powerfin64 Well-known member Joined Oct 27, 2003 Messages 600 Location Yakima, Washington Feb 19, 2022 #25 most likely it does have one, no I didn't remove it, no need to do so.
