This is an offshoot of another Super Forum thread.
To recap: the discussion started with a mention of Mr. Dan Holohan and his website www.heatinghelp.com. He has also written several books including the following:
The Lost Art of Steam Heating
A Pocketful of Steam Problems (With Solutions),
We've Got Steam Heat (an Owner's Guide to Peaceful Coexistence),
Greening Steam: How to Take 19th Century Heating Systems into the 21st Century.
You would expect it to be dry reading, but Dan's style of writing and humor make his books a pleasure to read. When I got Greening Steam, I couldn't put it down. I hadn't been that absorbed into a book since I read Harry Potter.
Bear in mind, I grew up in Manassas, VA in the outer suburbs of Washington, DC and had never seen steam heating until relatively recently. After reading Dan's books, joining the wall at heatinghelp.com, and enlisting the help of one of the reputable local contractors on the website's "Find a Contractor" section, I was able to take a very grumpy 1926 1-pipe steam system and make it silent, better performing, and a joy to live with.
A few things to know about steam heat:
If it clanks, bangs, hisses, or spits; something is wrong with it. It needs to be repaired / maintained. Until it is fixed, it will continue to be loud and will burn more fuel than necessary.
The lower the pressure, the better it will function.
Where there is air, steam will not go. Translation: Vent the air from the system effectively so the steam can work its magic.
There is no substitute for proper near-boiler piping.
On 1-pipe steam, the radiator valves must be either full open or closed. Throttling the valve (opening it part way) will cause banging, spitting, and other problems. To regulate the temperature output, change the air vent.
Never underestimate the importance of venting the steam mains. Vent them as fast as humanly possible, but vent them such that they fill with steam at the same time. (Where I am, there are 2 mains, one is 2X the volume of the other. The bigger one needs to be vented at 2X the speed of the smaller one).
In one of the books (The Lost Art of Steam Heating I think), I read about how 1-pipe steam heat was installed in rehabilitated housing New York City in the 1980s. This was done because the parts have a low scrap value (so people wouldn't steam materials for scrapping), it's simple to maintain, and durable as a tank. These systems were installed with modern venting theory and performed silently, efficiently, and generally exceeded expectations. Believe it or not, you can get new or salvage radiators today and have steam heat installed if you want. And yes, I'll gladly take a brand new 1-pipe system thankyouverymuch!
If you remove a radiator, I will personally hunt you down and make you regret that action. (You can tell I have as much respect and admiration for radiators as I do for a Frigidaire WCI-58.)
Just because the system may be a century old is no excuse for it to function in any fashion short of perfection. Also, steam can (and should) be EXTREMELY energy efficient. It's easy to do and relatively cheap as well.
I love Dan's motto: "A hundred years from now, they will gaze upon my work and marvel at my skills but never know my name. And that will be good enough for me."
Happy Steaming,
Dave
http://www.heatinghelp.com
Happy Steaming,
Dave
