fltcoils
Member
Make that "Oldsmobile Turnpike Cruiser"
"Friction loss in a large displacement V-8 engine turning at 3000 rpm actually can consurme more horsepower than it takes to push the car down the highway at 60 mph. lf engine speed can be reduced to 2000 rpm or less, friction is reduced by more than 50%. It doesn't matter that it takes a larger throttle opening to produce the same bhp at lower speed. Reduction in friction loss is far more important. In fact, the larger throttle opening is beneficial in that it reduces manifold vacuum, so pistons have less vacuum to pull against on the induction stroke. The pull against vacuum is known as --"pumpingloss" . It also is an important factor in fuel economy, but is not as important as friction loss."
..."The useful engine range with the test car's gearing is not 2000-5000 rpm as it is with normal high-performance gearing. It is 1000 rpm to not over 3000 rpm. The 3000 rpm figure represents about 65 mph in second gear and nearly 100 in high.
And, the engine is designed for midrange torque, not top-end horsepower."
Like my 2004 Buick Lesabre, which gets 34-36 mpg hy at 60.
