strange Danby DWM99-W washer
bpetersxx
Jun 6, 2008
1,810
laf in on the banks of the Wabash River
i am hoping that the fine folks can answer the question i have
I took the back off to see if i could put a different drain hose on
I do not think that can be done as the drain port on the pump is very small compared to other washers
But the dilemma I have is when i looked inside and saw 2 pressure stitched and hoses
one pressure switch hose goes from the tub to a y fitting with 3 port
another pressure hose goes from one port on thy fitting up thru the machine up into the control panel where the pressure switch that controls the water level with the water level knob
But one pressure hose goes from one port up to the right hand side of the machine where there is another what looks like a pressure switch
This pressure switch has a screw on it
I have tried to research it but cannot find anything on documentation to see what this is
I'll pause this for now
update
well i got it to operate
BUT and this is a big but
I had to jury-rig the safety system
I put a rubber washer used in washer hoses to seal them in the lid switch mechanism
this makes the safety lid switch engaged all the time
so the lid switch mechanism may not stop the washer if the load is unbalanced
i hope the fine members can add to this thread
update whaqtever
that auxiliary pressure switch is like in my Haier front loader washer
It prevents spin until the tub is drained
I put in the spin portion of the cycle
It sat and drained the water until the tub was almost empty of water
It spun with a little bit of water still in the tub
