Sudsy
retropia
Mar 22, 2010
1,296
Some of you may be familiar with the movie "Bachelor in Paradise." This youtube clip, featuring Janis Paige and Bob Hope, has a washer in it that demonstrates what happens when you don't pay attention while you add the laundry detergent.
What kind of washer is it?
Fun!
Thats when movies were fun,took your mind off of everyday things.Just enough flirting to know where people were coming from,instead of in your face sex.Some really good lines.I like the line,Ive never seen a kitchen with a head on it.
The O'K & M was one of three made by the Automatic Washer Co. The other two were The Automatic & the One Minute. Both of those were wringer washer makers. This was the combo that did not spin at all and had something like a 90,000 or a 100,000 BTU burner for drying. I would imagine that it could not be vented with flexible plastic tubing. I wonder if it required double wall flue pipe. I did not know it came in yellow. The only other one I saw on TV was on the Donna Reed Show and that was in black and white.
O&M for sure. I found a gas burner and control service manual that had the O&M combo - this is it. The specs show it has a 29,000 btu burner, a misprint? Perhaps it was 129,000 btu and the typesetter "corrected" it for the manual? Operating temp. was 188F when control was set to #5 position on the dry-dial.
Pretty machine! (They were pouring the soap powder into the lint-trap.)
That was a funny movie Doug, our car club watched it a few years ago, and that is indeed an O & M Gas combo, in fact these non spinning combos were wisely made only in gas drying models. [ The electric models could not be installed more than one half mile from the Hoover Dam due excessive voltage drop they would cause in all of southern California. ]
 Thanks again for posting it Doug
Seriously, it went from the drain after the last rinse into dry. That 100 or 129 thousand BTU burner came on and just burned and blasted the moisture right out of there. Look on the plus side; it was wonderful for wash 'n wear, no chance for wrinkling caused by spinning. Of course, none of the early combos except the Duomatics spun fast enough to wrinkle wash 'n wear. What a shame it was never tested by the consumer mags so that we would have some idea of the drying speed. It probably was pretty fast given that the BTU input was almost 3.5 times as great as the next highest burner input, that of the WP gas models with 37.5 thousand BTUs and the OK & M's operating temperature was somewhat higher on the maximum setting and this max temperature could be achieved faster with the larger burner. The OK & M should have been an efficient dryer since it was basically built as a water tight dryer.
61 Chrysler!!
300G...413 two four barrels, 375 horsepower!!!!!Ram Induction, pushbutton torqueflite!!!! and that georgeous Dodge!!!!!Oh to go back in time when gas was 30 cents for 100 octane high test and REAL cars ruled the road!!
