All -
The water level in Jamie's machine is just about right. There are some videos on YouTube from other contributors here of similar era machines which also have the fins above water.
This agitator was designed in the mid to later 1970s for the original large capacity tub. This machine is NOT the original size tub.
Starting in the second half of 1981, the large capacity belt-drive was re-designed to use less water. This was a physical redesign that affected the baseplate, suspension rods, outer tub, and inner basket. At the same time a common baseplate assembly was devised that could be used for both capacity models. Previously, different baseplates were used for standard and large capacity models. The new tubs are .75 of one inch shallower, or less deep as compared to the 1967-early 1981 units.
As a result, the far top fins, which had been just barely submerged in the early 1981 and older machines, never see water in the newer machines as the agitator rises .75 of an inch higher in the center due to the shallower tub.
The shortening of the centerpost (done in January 1978) had nothing to do with the water level depth and did not affect any dimensions of the machine except for the centerpost and spin tube.
Gordon
