Detergent and other tips
Hi BTJustice,
Congratulations with your new 2140. I have had the same washer for 15 trouble free months and counting.
I agree with the need for HE detergent. By the way, Kirkland detergent is HE rated and is available in a free/clear formulation (no dyes) or one with fragrance. For what it's worth, Consumer Reports recently rated Kirkland as high as Tide HE for cleaning power, and it's much lower priced.
I am still using up a large bottle of All Free/Clear and a second unused one of Tide HE before trying Kirkland. In 15 months, I have used up one large bottle of All, one of Tide HE, now I'm on All #2 and the second Tide HE is sitting on a shelf in the garage, unused. Basically, two bottles took me through a year, running about five loads a week.
I generally use 1/4 to 1/3 of the provided measuring cup (we're talking about the big container with the spigot that includes a free measuring cup. If you cannot rinse out the suds even with Extra Rinse, cut down on your detergent. Ideally, you should see no foam or just a little clear light foam on the door when you are done washing. The smallest amount of detergent that gets your clothes clean is best.
A few other tips:
1. I don't even use the dispenser. Not at all. If you pour liquid detergents into it, eventually it gums up and you have to clean the damn thing with a toothbrush. Instead, I simply place the cup with the detergent in it on top of the clothes. The dispenser simply drains the detergent into the tub, without any delay, so I keep the dispenser clean. When the wash is done, the cup is nicely rinsed out. I learned this trick from European friends who have used FLs from Day One.
2. No bleach, as others have mentioned.
3. WIPE OUT THE DOOR GASKET at the end of the wash day. Use a small towel or sock and throw it in with your last dryer load of the day. I understand that they improved the 2140 by placing drain holes at the bottom of the gasket. My model does not have the drain holes. Even if you DO have the holes, it is good practice to wipe the crease dry to avoid mold buildup.
4. Leave the door ajar to allow the machine to dry out. I've never seen anyone in Europe ever keep the door closed, they all leave it ajar.
5. Water will siphon through the dispenser whether you use it or not. I often find a little water in the bleach section of the dispenser. I leave the dispenser door open between washes to keep it dried out.
I live in Southern California, my laundry is in the garage, and the garage faces due south. So it is not unusual for the temperature to top 90 F in the garage on hot summer days. Even with this adverse environment, I have had no mold or odor issues by following this regimen.
About two months ago, another reader with a 2140 posted a piece on how to remove the dark lens, so you can see inside the washer better as it's running. I saved the article and can mail it to you upon request, or post it here.
