Tappan wall ovens - Bloomfield Hills MI
That may be one of the coolest things I've ever seen! It would be fun to cook a big hunk o beef in. Would it be able to use modern popcorn bags? What happen if you start cook time before warm up? Is it just one power level? The other controls are for thermal cooking? What is the little drawer for?
Cardboard paper - laser 3D could do it? A one-off would be most likely unfriendly in cost.
Just thinking ...could you approach some cnc shop that would be able to cut and shape a duplicate? I worked around factories for automotive and saw plenty of tool and die...so, can't help asking why not, but ...maybe there's a part in a unit, somewhere out there, just waiting to be adopted. Hoping for you.
I don't know the requirements for that piece, but that sounds very creative! Thomas Edison would have as much or less to work with, creating a lighting filament. :-)
Anthony,
Could you provide more detail on the RF gasket? I'd like to see ID and OD as well as overall thickness. It appears to have been an embossed with a waffled pattern, if this is the case it would be good to know the material thickness before it was formed too.
A few more good closeup photos wouldn't hurt either. Photos of the mating surfaces of the tube and the waveguide could help too.
As both a Ham (RF guy) and machine shop manager, perhaps I might be able to help with this. I looked in the Parker Chromerics catalog and they sell expanded metal foil. It may be child's play to duplicate this part.
Phil
Anthony,
Sorry for the delay, things are been pretty crazy for me for the past month or two. You can try to call whenever, evenings are probably best, leave your number if you hit my VM.
You could email me at [email protected] if you like also. Would love to see a few more photos of the gasket. Reasonably accurate ID and OD measurements as well as the base material thickness and the expanded thickness would be good to have, should do fine with a standard caliper. Also any hint as to what kind of metal its made from? I think all the Parker Chomerics expanded RF gasketing material is Monel (Google Porcupine Metalastic). Material probably doesn't really matter too much but it should be pretty conductive.
Photos of the two mating flanges may be helpful too. Are they pretty flat (at in machined?). Sheet metal or thicker? Good to know what kinds of gaps need to be filled.
Up date
So after contacting a few company's that make this kind of gasket all told me they would not do to me only needing one :( so I took an old magnetron gasket off a rader range starched it out and~ it now works like new! :) who is happy this guy!
