Tell me again how to get the stink out of colored towels?
jmm63
Silver Member
May 26, 2003
805
Denville, NJ
I've got a set of green towels that match the rugs in my bathroom, and I just can't get that funky smell out of them. I've tried hot water, vinegar, extra rinse, extra dry, no fabric softner etc and you use them once and that smell is back. Short of throwing them out and getting all white towels (those never seem to smell probably because of a little bleach) what tricks does everyone have?
Is the "funky" smell more of a mold/mildew wet smell or New dye smell?
If it is Mold/mildew wet I would suggest washing in as hot of water as possible and then hanging them on the line to dry and air out. Maybe some sun and wind will help them.
If it's new dye smell. Several washes will take care of that.
Quat Sanitizer
I have used Quaternary Ammonia sanitizer to remove mildew odors from towels and other fabrics. I got Array Quat-Clean from GFS, but P&G, C-P and other brands offer them also. I use a large bucket or tub to soak them in. Follow directions on package as to how much to use, based on amount of water in tub.
You will find this product in food service and janitorial supply places. It runs about $30/gal.
Send them to the dry-cleaner and have them washed in an organic solvent and not in water, then, when home wash them in hot water, voilà! New smelling towels! :D
I know that's strange but try it for yourselves, it really works!
Lemon Ammonia...prefer Parson's brand...one cup in the wash with detergent and the hottest water possible...but warm usually works...regular cycle...all odors including ammonia will be gone at the end...o can extra rinse if you want to
I've had best results
with very hot water, (150F or above,) an enzyme detergent, and BAKING SODA---at least a measuring cupful.
Good luck,
Lawrence/Maytagbear
Clorox Ultimate Care Bleach
Run the towels through a Rinse Cycle with a little of this Ultimate Care Bleach. It is not a strong as regular Clorox.
Let them spin out, then was and rinse as normal.
Colored towels? I vote for warm/very warm water and a dose of borax or soda with detergent. Line drying sounds like a good idea too.
I wonder, is your washload turning over well? Is your dryer drawing bad air? Are the towels being hung up or balled up after use?
The dryer has more to do with it than the washer.....
Your towels are taking to long to dry in the dryer, and as a result smell moldy/funky when they get wet again, I had the same problem, check your dryer vent, it sounds like it is clogged to me, as far as the smell, it is a pain in the ars to get rid of, it always seems to come back, I would recommend a hot water wash with powder detergent, either Tide or Cheer. Let them dry outside as well.
Mike
If the odor is mold or mildew, a product with fungicidal properties is best, as you have to kill the fungus that caused the smell in the first place. Otherwise it will come back. Boiling them for a while should also work; but that may remove some color. Sudsman will know the trick to use for sure.
Try using borax. Works like a charm for me and its all natural. I use Borax with Tide Powder, The new OxyClean MaxForce tabs that i just love and warm water. Borax will get rid of most odors and it will leave a sweet clean smell in your towels.
Let me take a wild guess. Is your daily driver an Affinity? Mine never uses enough water on a full load of towels. I end up adding about 3 gallons more by hand. The towels will stink otherwise.
Wow, thanks for all the idea. Washer is a Kenmore front load, it doesn't smell so I know its not coming from there. Towels are hung up after use so they dry out, no more than 3 times before washing. Dryer has new ducting and dries things nicely, I even put the towels in longer after they are dry. I'm going to start off with the ammonia and line drying to see if it does anything.
Liquid Lysol
I've never used it in the wash for anything, but I love that smell. That's a strong smell of a chemically-enforced clean that I always feel good about.
For me
Tide, 20 Mule Team Borax, and 160 degree hot water always does the trick.
That happened to my kitchen hand drying towels a few weeks ago when I'd let them go longer than a week without washing.
Another vote for 20 Mule Team Borax....that and the Sears Ultra Plus with a good hot wash and line dry will take care of almost anything funky smelling that I have.
Stinky towels
I have a set the three dishrags I bought at Meijer (like Wallmart but a chain out of Michigan). All their towels are made in foreign countries, when I used & washed them, they all changed color, don't remember the origional colors. If I don't hang them up to dry after I use them, they smell musty. They've been washed a lot in hot water & powdered Cheer, still smell when used. I have other dishrags that are Cannon & made in USA, they don't smell or changed color even if bleached. I have a Frigidaire 1-18 so it's not the washer.
I always wash my towels at 60c now after having the same problems as you. Any lower temp than this does not kill the bacteria and the smells return. Washing at 60c gets rid of the odours.
I've only ever had this problem with cheaper liquid detergents.
Try powder (good quality stuff) bleach shouldn't be necessary.
Persil & Ariel colour do excellent jobs on towels!!
It's Not Hot Water Per Se, Nor The Lack Of It
But one needs something to help "sanitise" one's washing to deal with any bacteria/odors.
Problem with most liquid laundry products is they do not contain bleach, and using hot to boiling wash water can cause excess froth.
On the UK/EU side of the pond a good detergent with a built in bleaching system, or added on it's own should solve the problem. Both sodium percarbonate and sodium perborate both release oxygen in wash water, which in turn helps deal with "germs" and odors. Activated oxygen bleaching sytems go one better in that the peracetic acids formed are a stronger bleach and disenfectant than plain hydrogen peroxide at wash temps <120F.
If the whiff is due to mould or mildew, even the hottest water alone may not due as such things form spores to deal with inhospitable conditions, and quickly come back to life once things are good.
For the above you need something that kills mildew/mould. Some chlorine bleaches, oxygen bleaches, peroxide, quats, UV light, etc.
If the towels are coloured, washing at temps >140 with oxygen bleach can cause fading.
Personally have found that once an item has been subjected to any of the above, and still has a whiff about it, then into the rubbish it goes (yes, sad and wasteful, but consider time and product cost in trying to rid them of the whiff instead), and purchase new.
IMHO much like knickers, drawers and bed linen, the only satisfactory colour is white, in either pure cotton or linen. Such items can be washed the daylights out of if required, and if well made, not suffer badly.
I also suggest using Borax. Not only does it remove odors, but it helps to kill fungus/mold.
You might also try cutting back on the fabric softener. A build-up of softener can lend an off-odor to freshly laundered fabrics.
In addition, maybe the problem is lurking in your linen closet? Is it next to the furnace chimney?
