Mark -
Let me guess, your washer's model number is 110.7005700 or something nearby up to 110.7005704. If it was 110.7004700 (non-suds) the first few revisions use timer 362357, while the later versions use timer 363089. They both sub to 373844 as the last available WP/FSP timer.
The "pedestrian" 60 series non-suds machine is model 110.7004610. These went all the way up to 110.7004619 in revisions except for some reason they skipped 612 and 614. Early versions use timer 363385 which subs over to 379372, which was a very common timer and is still typically widely available on ebay. This timer was used in several other mid-line machines from 1970 that I have or had.
Thus the 60 and the 70 didn't use the same timer. That is not unusual, as Sears usually spec'd a different timer for machines without solenoid controlled dispensers. The 70-series' timer may have been useable in models with water flushed detergent dispensers as well. Some of the engineer's rationale often doesn't seem to make sense as to why they used what, but it clearly made sense to them at the time. Sometimes the only difference in a timer is the presence of a dry agitate in the normal cycle or not, whether or not the timer can be used as-is in suds models, whether is has fast or slow agitation in Pre-Wash, etc. The difference may also rest in how the knobs attach as well (some had timer hubs and others screwed directly on).
I think the 60-series model from your catalog shot was pretty long-lived. It was even re-invented in 1972 with a bronze color inset on the left console instead of charcoal.
Gordon
