The amazing and gentle Gyrafoam action of my Maytag E2LP
bradross
Feb 21, 2008
734
New Westminster, BC., Canada
Thought I'd just share my laundry experience with ya'll today! I recently received from a cousin a very old, woven jacquard bedspread that belonged to my great-great grandmother in Iowa. I had seen it in old family portraits dating back to the 1880s, when it was used as a backdrop for photography. Well, it REALLY needed cleaning, but as you can imagine, I was a little hesitant, given its age. Well, I decided to use the old wringer washer, as that way I could closely monitor the wash time, and the "gyrafoam" action of the old Maytag seems fairly gentle. I also feared the spin cycle on an automatic could damage it. Well, it turned out BEAUTIFULLY! It's amazingly soft and clean. Seeing it now, one would never imagine it's about 130 years old or more!
All of these recent Maytag wringer posts are really making me anxious in finding a decent machine. I have had thoughts of using a variac on a wringer for precise agitation control, especially on delicate fabrics or awkward loads, like shoes. Can't use a variac on an automatic without pissing off the timer, as well as other controls that rely on at least 110v for proper operation.
Have No Room For Another Washer
Wringer or otherwise, but am keen to find a good mangle in working operation.
Why? Well for just the sort of item spoken of above. Large bukly but yet delicate items such as bedspreads, quilts and even some older wool blankets. Such items may or may not fit in the Miele, but even when or if they do their weight when wet can lead to damage. Know of one domestic front loader that literally bashed itself to bits trying to spin a heavy quilt.
One could always take such things to the laundromat and use the 50lb commercial washer but there we run into several problems. One, am getting leary of public wash houses what with the plague of bed bugs that seems to be infesting NYC at the moment. Then there is the lack of control one has over coin operated washing machines. Once the money goes in/machine starts that is it until the program is over. Should the item begin to ball up, colours start running, or you can see seams starting to break via the window, you are out of luck. Well suppose there is asking the attendant to some how cut power/stop the washer, but what does the good of that? You still are stuck with a wet heavy, and now maybe damaged item.
Ooooooh!!
Please share some pictures of that blanket!!! Would love to see a before washing and after washing. I'd even be afraid to run it through the wringer on the Maytag after washing and rinsing.
Reading this thread makes me sorry I sold the E2L that my wife's uncle had. It originally had the rubber footpad to operate the wringers, but Uncle Edmund put a screw in to disable it. Sold it for $45 dollars to a young couple that wanted to save on laundromat costs. DAMN!!!
Wringer Washers
Hello, I'm a recent member and I'm fascinated with these wringer washers. I too would love to see the before and after pics of your family heirloom. Can anyone comment on how large or bulky an item may be successfully washed in these machines? Thanks much!
reply to JaredH's comment ...
It appears there might be a little confusion to the reference of "130+ years old". I'm not referring to the machine (which is a 1977 model), but rather, the bedspread, which is precisely that ... at least if my arithmetic serves me correctly, 1880-2010 is 130 years.[this post was last edited: 1/16/2011-18:26]
Bedspread pic # 1
As requested, here are a few shots of the bedspread. As a jacquard/damask weave, the pattern is the same, but reversed colors on each side.
I didn't think to take before pics, but not sure if anything would have looked that different. There weren't major stains - just dingy in general, with a smell of mothballs.
E2LP
Hi all. To answer cmiribison s question, I would say about half the amount that you would put in an average size top loader, I have a Maytag E2LP and thats how I do it? I have washed a heavy wool blanket in it (by itself of course) and it worked out fine.
Was the bedspread run thru the wringer-would think the wringer could cause damage like a spin cycle?would think a 130 yr old fabric item would be as fragile as paper.when I visited the Smithsonian's "restoration" depts-they washed fabric items such as that in a very large,shallow flat tank-and with no agitation.The object was kept flat as possible and moved to a special dryer that again kept the fabric document flat.No wringing,agitation,or spinning.This process is used by them esp on very old flags.
another "Great Thing" about Wringer washing
Is that there is no outer tub the dirt and nastyness go down to the bottom, and is filtered by the lint screen. The washtub, and screen can be cleaned out, or sanitized before the rinse or next wash if necessary. If one is forced to use a conventional washer, say in a laundry mat, you never know what`s lurking beyond the holes of the inner tub. Launderess is right "no unbalance situation" the worst thing that could happen, is the wringer washer may want to walk a little but that what the break wheel is for. Best to all
Rex, when you have a large, bulky item to put through the wringer, you unlock the roller tension and feed it through. Easy used to make a point about that for their spin dryer washers, saying that it was easier to damp dry items like bedspreads, blankets and quilts in the spinner than with a wringer and it probably is, but it can be done with a wringer.
Vintage Items
Well yes, it would depend upon the condition of the item when it comes to cleaning and or "extracting". A heavy but vintage quilt that is very fragile probably won't withstand extraction by either wringer or spinning without a real risk of damage.
OTHO a heavy wool blanket or whatever that is in good condition should be fine.
Most all my vintage laundry manuals give directions for using a wringer washer or mangle (all that was around at the time), when cleanng "comforts", quilts, blankets, coverlets and so forth. As another poster stated upthread you had to adjust the mangle/wringer rollers to suit.
Wringer vs Extraction:
Machine extraction will most always remove more water, detergent residue and so forth even at lower speeds than a wringer. Though each involve forces of compression, a machine can do so (hopefully) by some what evenly distributing weight of an item. On a wringer one has to keep feeding the item through several times, each pass requiring closer and closer spacing of the rollers to squeeze out water. If this is not done properly it can lead to textile damage, especially if air bubbles are trapped at the end of whatever and have no where else to go. For this reason items like pillow slips are always fed into any mangle/ironer/wringer *closed end first*.
Cleaning anything heavy that will only become more so once wet, such as quilts, blankets, coverlets, etc can be a challenge for front loaders. Normally one attempts to have a mix of items in a load so the machine can properly balance, and for good washing action. Large bulky items may by themselves reach the dry weight limit of a washer, and adding another heavy item such as a towel (for balance), may not help things.
What normally happens is the bulky item balls up upon itself, and if the washer isn't careful about spinning, the first attempt can send that heavy wet thing slamming against the drums. Many a domestic front loader has seen it's shocks shattered, concrete balance weights destroyed, and or simply bashed itself to death.
Further to "Launderess's" information...
And to answer Rex's question - I suppose I was being rather bold in washing it at all, but I closely examined the fabric and it appeared to be in fantastic condition for its age (it actually feels like it could be a blend of wool and cotton). The Maytag wringer's tension is pre-set, and is not really that tight, unlike some other brands whereby you could manually increase the wringer tension by tightening a screw on the top of the wringer housing
Believe it or not, I even threw it in the dryer! Now that was probably REALLY stupid of me, but I monitored it throughout the drying cycle, and as I said previously - it came out beautifully.
And just in case there are any skeptics out there, I've attached the photo showing it as a backdrop behind my great-great grandparents (seated, circa. 1890). I'm assuming it wasn't new when the photo was taken.
Brad ... great photo of your family AND the spread!  WOW ... to be able to have the original spread.  A testament to how well things were made.
It doesn't suprise me that the E2LP handled it with ease; those were really great machines.  It's all in how you feed the item through the rollers, isn't it?  As long as you can keep the item as flat as possible, it works well.  Believe it or not, that's when the silly safety foot pedal came in handy.  You could just lift your foot and readjust the item and then press it again.  That's about the only thing that crazy thing was good for!
The gyrafoam action of the Maytag conventional is gentle but thorough.  The big tub of the E helps, too.  When filled full, it uses 18 gallons of water.
Did you use the "soak and agitate" method of washing or did you just wash it for just a few minutes?  I usually let mine run for just a few minutes when I do blankets.  Did you rinse in the machine?
One time, a few years ago
I was testing Maytag's capacity and I washed a full mixed load on Extra Large in the WP/LSP9245 BO. Then I drained & spun the water into the Maytag J2L , transferring the clothes into the big square white enamel tub. The old girl did just fine, some of the items gliding flat across the surface before going under.
Cool to see, but you need a really big load for the Gyrator to execute this square, up, across, down current. At full water level, you can also see how gentle yet thorough the action is. Normally though, I use less water and smaller loads and the action is vigorous and dramatic.
The WP holds 21 gallons at this level, and I'm sure Geoff is right about the Tag's 18. I think I pumped all the water in, though; it was full to the gills. Will have to do it again some time.
Great picture!
Now there are some true class people.
Love the clothes. If only today we still dressed like the victorian era. Men in our 3 piece suits, pocket watches, and crazy beards that make us look like Johannes Brahms. :)
