The GE HydroWave: One of the worst washers ever
whirlpool862
Mar 3, 2025
161
Columbus, OH
Lately one person has been defending GE’s HydroWaves and their Model-T machines, but they were terrible machines.
I’d much rather even use a Samsung machine than a GE HydroWave, at least when a Samsung gets off balance it’ll redistribute, while a HydroWave will destroy itself before of the lack of balance sensors.
I’d much much rather use a modern VMW Maytag than any GE HydroWave.
I’d also much rather use the newer GE than the HydroWave. The newer GE’s, when off balance, redistribute the load, while HydroWaves will just destroy themselves.
The mode shifter was also a common failure, whether it was the bearings or the coil. Either it would wash the whole drum, or the bearing failed making it really loud.
The DAA ones and the infusor ones both didn’t clean properly, but the Infusor variant of the Hydrowave was even worse.
The reason why bearing failure was so common with these was the upper seals often failed, causing water to leak down into the bearings. The HANNING pumps on the HydroWaves and Model-Ts were rather loud as well as the motor.
Another common failure with these was that the washer would often rub against the bottom, causing it to make a loud scraping noise on agitation modes.
When the more shifters failed, it often caused it to bang or squeak on agitation.
When the mode shifters worked, it sounded like chains rattling when engaging.
Some people even reported stories where their HydroWave got so out of balance that it flung the cabinet of the washer open or made the control panel fall off.
Another common failure of the Hydrowave or motor T was if the overflow tube got clogged, it would flood your either house. On a modern Whirlpool VMW, the washer will drain out the excess water by running the pump.
There were also issues with the inverter motors where the internal bearings of them would fail, causing it to make a horrible noise on spin, or the inverter motor failed.
They also used this system on commercial washers, which was an otter disaster because this system didn’t even perform well on a residential setting, let alone a commercial setting.
Overall, the HydroWave was one of the worst washing machines GE ever made, after just 3-6 years, the mode shifter often failed. They also didn’t have good cleaning performance and they weren’t that quiet on a spin cycle.
I cast my vote for Hydro-wave. Not only did Hydrowave lack durability and longevity, but their cleaning was worse than the model T. I'd go to further say a 2025 BOL VMW impellar washer can out clean a Hydrowave which is just shameful for me to admit.
I have one of those VMW Impellers from 2014, and I heard that these older ones actually have decent blooming since mine has the tall impeller. Mine is WTW4900BW0.
The flat impeller versions (like the WTW5000DW) I heard didn’t clean as well. I do think the dual action agitator models do clean better.
But almost every washer is better than the HydroWave, even a 2025 top of the line Whirlpool VMW impeller smart washer I bet has better cleaning performance than a GE HydroWave.
Although top of the line Whirlpool VMW’s really don’t have the best cleaning performance.
Bottom of the line Whirlpool VMWs (like the Amana NTW4516FW) have a dual action agitator. The older versions of the cheaper VMW’s (like the WTW4800XQ) were even better as older models like that used full water and a dual action agitator.
The older VMW’s in general have better cleaning performance than the modern ones. Impeller machines do better with low water, not too high.
A major issue with the newest Whirlpool washers is the cleaning performance, and the higher end the model is, the worse the wash action is.
The “agipeller” machines are just impeller machines with a stick. Don’t be fooled by those.
The newest GE machines and the Whirlpool VMW’s are a lot better than the HydroWaves. Even a Samsung top loader is.
I hate to admit this, but even a flat impeller Whirlpool WTW5000DW probably cleans better than a Hydrowave.
And older BOL VMWs had a water level switch, and they weren’t high efficiency. But those were discontinued due to some 2015 regulations. So now all VMWs use auto sensing to save water.
The HydroWaves were so problematic and most broke down at just 5 years. When the HydroWave came out techs would warn you to not buy GE.
GE!
I can testify to this. I have done a full sized dark load and the load didn't even turn over. I had to spend a dollar to do a full cycle. In other words, I had to run the machine twice just to get the load washed and rinsed properly. And this was in a college dorm. The model T my dad had did a much better job than that stupid hydrowave. What made the hydrowave worse was the fact that it did a shower rinse. That's why I had to run a second cycle to allow the fabric softener to mix through. Bad idea.[this post was last edited: 5/12/2025-14:17]
Give this a rest already
That person likely created a new thread defending the Hydrowaves and T series in response to your other thread being against them. It makes no sense creating another thread discussing the same topic all over again. We get you and some users don't like them and that's fine. But you should respect to other users myself included that actually like them especially to those that are still using them today.
I've used one in a college dorm. Never again!
Excuse me, but I've had bad experiences too. I had to run the machine twice to get the clothes rinsed properly. Agitation was so weak, even on the most intense cycles. This is so stupid!
Even the Speed Queen Perfect Wash is better than the stupid GE hydrowaves! I swear!
I have a Hydrowave from about 2008 in semi-active use-still going,but the basket is starting to clunk back and forth during agitation after years of use and timer will stick at times,so have to watch it a little...There is two agitation motions this does during the wash cycle: short fast stroke and long slow motion. The mechanism uses a 3-phase inverter driven induction motor with about a 1" pulley driving about a 11" pulley on the agitator shaft. Motor revs to very high RPM for spin. The PM wet rotor drain pump is noisy as hell and if the washer outlives the pump,will sub out for shaded pole vortex pump from an earlier model t washer. Last year junked a 2011 Hydrowave that died from leaky main/ruined bearings after a long service-machine stopped when the belt shredded, there was bearing balls, rust stains, belt debris all over in the undertray. several parts were salvaged including motor.
I replace my Hydrowave back in 2019. In use from about 2012-2019, brought from Home Depot. Control board and maybe inlet valves were going, and by 2019 no longer in production so I was not sure you could get parts. I thought it was an smart way of agitating the clothes. GE stated "the sound you hear (sloshing) are different from ordinary washers". As for cleaning, I guess stains were an issue, but I usually pretreat stains anyway. So to GE, thanks for trying something new and unfortunately I believe GE quality was better than other American manufacturers.
Did you see any grease or oil?
Whoever designed it should be incarcerated. What the heck?
I wish GE would be legally and financially held accountable for the Model Ts and subsequent Hydrowave shortcoming. Considering how many premature failure warranties GE failed to honor, there technically could have been a class action lawsuit.
Don't get me started with the transmission failure. How much oil do you think splattered everywhere?
Completely and utterly ridiculous.
What an authoritarian thing to say.
GE broke NO laws in the production of the T series and Hydrowave washers. In fact, they made GE lots of money and gave owners years and years of mostly good service.
The constant emotional tirades on this model of appliance is highly medically questionable.
The last washing machine that I owned with an electro-mechanical timer was a GE Hydrowave that I bought in about 2010 and used with no problems for over 2 years. I thought that it was a pretty good, simple washing machine. These GE washing machines have gotten lots posts that complain about how terrible they are which I don’t really understand from the experience that I had with mine.
Eddie
BTW, I got rid of that GE Hydrowave for an LG FL because I was feeling guilty for using so much water to do the laundry. I had always been a proponent of FL’s before buying that LG FL which was a complete and total disappointment!
I so wish that I’d kept that dependable GE washer that always did just what it was supposed to. In contrast that LG FL was terrible! It refused to spin any load that contained heavy items like heavy weight bath towels and throw rugs, things that I’d never before had issues with washing in any other washer before.
Plus on the normal cycle it sometimes would go through the entire wash portion of the cycle with some areas of the load never even getting wet. The WORST washing machine that I’ve ever owned in my life!
Eddie
Stop lying! Tell that to the thousands upon thousands who had issues with model T GE's!
I’m not lying.
Until you and Chet provide hard mathematical data and evidence that “thousands and thousands” of people were cheated by this product. Then I don’t believe you. That’s how EVIDENCE works.
There were no lawsuits or recalls in the news that I can find on T series washers and Hydrowaves.
They weren’t good machines but people are just lucky. There are also some Chrysler Sebrings on the road with 300,000 miles. Does that mean they were good cars or they normally lasted that long? No.
The Hydrowaves had similar issues to the model-T’s because they were similar machines (both had seal problems, tub strap issues, and the rusting of the bottom hub). HydroWaves had even more issues than model-T’s due to their DC Motor (the bearings sometimes fail in the motors causing a loud whining noise on spin cycle). The mode shifter was also a common failure point, either due to a bad bearing from a bad seal or a magnet failure where the washer spins the whole drum during wash cycle, a weird squealing noise on wash cycle also is quite common when the mode shifter is bad.
The washers were poorly designed but many people have awful quality washers still going, the only washers that went nearly distinct was the top loading Neptune or the Calypso.
The HydroWaves had a normal spin speed, spin speed was similar to a model-T although the motors were a bit louder on spin cycle (despite being much quieter in agitation). The HydroWaves had a louder motor when they spun out.
I’ve heard HydroWaves with bad motor bearings (rather than mode shifter bearings), can usually tell which is which because when the mode shifter bearings go out they make a roaring sound but when the motor bearings fail it makes more of a whining sound.
You often can’t tell between a Hydrowave and model-T when you first buy it (unless it has a control panel different), tho a lot of the oldest HydroWaves had the same control panel as the oldest Model-T’s. You can tell by the noise it makes, if it goes “whoosh whoosh whoosh”, it’s a Hydrowave, if it goes “chug chug chug”, it’s a model-T, if it has a true brake, it’s a Model-T.
If your washer has the jet engine slowdown sound and has the stator type of sound during spin cycle, then it’s also a Hydrowave.
I’m not lying.
You're lying! I've seen GE commercial machines failed! One was nearly blown apart at my old college dorm! I'm serious! It's not funny!
If you smell oil during operation, it's a model T.
This thread makes me miss my old T set even more now. Also makes me want to find one to have as my ideal basement set as well preferably this one since I always have a blast using it at my cousin's cabin.
