Soap draw
Hello richard
If you disconnect the hot fill on this machine bear in mind that it will not take powder in from the right hand soap compartment, Cold is taken in on the left hand one (pre-wash) only and hot only on the right hand one (main wash).
Twisted drum
Erm just check it by pushing the tub up and down a few times then let it settle if the tub is still out of true then as andy says you will need to fit a suspension kit, on a machine of this age if it has not been done before it will definately need one by now i would say, i have done loads of them and it is a bit of a pain in the arse to do.
Gary
