Easy combos were introduced in late 56-early 57 and manufactured through 1963. Easy offered the largest number of models in their line, second only to Philco, probably. The basic design of the machine changed little because as I said somewhere, nobody except Sears/WP had enough capital to invest in a complete redesign of the machine with the disappointing sales failing to return the initial investment expenses. The high point came in 1958 with 180,000 units sold, but by 1964 that figure had slipped to 27,000 units. And how much could they redesign when they were so constrained by the threat of patent infringement from AVCO? 1964 was the last year that Speed Queen produced their combo, although there might have been some sold the following year. Philco stopped in 1968. 1961 into 62 was the last year WP sold the combo under their own name; from then on it was only sold as Kenmore. Maytag pulled the plug on their combo in 1965, but Westinghouse was done by 1960 and mercifully so. GE lasted into the early 70s, largely on builder sales to apartments & condos. The Watergate had GE combos. GE and Kenmore, the last two in the game, sort of put down their cards and pushed back from the table about the same time.
John and Jeff had/have the two motors so I guess they saw the machine and can be more authoritative about this than I, but the Accelux motor as it was called only did bursts of acceleration during the 4 rinses and then to extract before drying so there was tumbling with bursts of speed. That fast acceleration was kind of radical for the combos because most had slow spins and slow ways of building up speed except for the combos with transmissions and the Easy. What they did was very smart in a way. I don't know the proper language to exlain this, but an unbalanced load spinning at slow speed makes for an exagerated swing out of the center position wherever the heavy part of the load is, but if you quickly speed up the drum with the load, not only do you have a better chance of more evenly distributing the load, but the higher rpm means the heavy side is moving around in a circle so fast it is producing a less exagerated swing out of the center position. Distributing a load around a larger diameter drum was a problem with the combos just as it has been a problem in the larger drums of FLs today. So Easy did that. With the rubber cups screwed to the floor to hold the legs in place, the machine did quick speed ups and long coasting periods for the spin. It made best use of strong G forces or C forces for Centrifugal force, helped eliminate vibration from sustained periods of spinning and, by mounting the motors at the top of the cabinet, it allowed the tub of the Easy to sit very low in the cabinet which was also a stabilizing factor.
Philco might even have borrowed the physics behind this when they reduced the machine to its 27 inch width. The original low speed spin stage of the 36 inch machine could not be be accommodated in the narrower cabinet because the tub swung too much and crashed into the cabinet sides so they went to the timer increment between the last rinse and the final spin where the machine briefly accelerated, then coasted a few times to remove enough water from the load so that it would not pack so tightly in the high speed spin that it would stick to the tub afterwards. If it did not fall from the tub after the spin, the load would not dry properly.
