They're Here,,,,
Yup. Three of them.
The 18 built in I've had.
Avocado is the ABC Rescue Trip to New Jersey and Scranton Pa. All in the same day.
Coppertone is a Local that popped up the next day after I got back from Scranton. That one is from Buzzard's Bay. (Yes, there really is a town by that name).
All Racks and Wash Chambers are in Really Good Shape.
I also brought over the Westy Terrace Top today. Plenty of projects for the Holiday.
Those 58s are mint.
Water Testing tomorrow. The plan is to make 2 Stellar Machines and part the Odd Man Out.
Westy gonna get tested and then Fluffed and Buffed
Eddie!
Wow!  That avocado one looks minty fresh underneath!
I'll vouch for you re:  Buzzard's Bay.  I remember seeing it on maps when vacationing on Martha's Vineyard.
Hey Ralph.
And the Copper is just as good.
If I get some motivation I'll get some pics later or tomorrow. But yeah when I hauled it into the truck it looked pretty spotless too.  Too bad they butchered the Hoses for the Unicouple.  They "hacked" it into a Freestanding Machine by extending the hoses in the worse possible way.
The Avocado's Top was so gross, I left it at it's point of origin. Copper's Top will look good after some heavy sanding and 10 coats of mineral oil.
OK OK...
Here are the under the skirt shots of the Copper.
Some wicked nasty mold thing going on inside. Hot water and Bleach with a Sani Cycle orTwo
I can't even photograph it. NASTY. Maybe tomorrow before and after.
Here is the Buzzard's Mechanics
Nice lineup Eddie! Is there one heading in your kitchen soon? I also have a 18 that I think should end in the kitchen someday! I haven't played much with the few non-Frigidaire dishwashers I have, I think I should!
Hi Phil.
I want to have the Avocado in the Kitchen tomorrow or Christmas Day. My gut is telling me the I guess we'll call her Eva (Avocado) is going to fire right up and (fingers crossed) will be Plug and Play.
She'll need a good Bath, Scrubbing, and something to get rid of the Scent of 99 Glade Plug-ins that were in that apartment.  Man, those things are nasty.
Does anyone know of something that I could spray her with to Neutralize that stench ???
If you have an KDS-18 Phil, they're I think KitchenAid's Pinnacle of engineering. Best Cleaners and they use a Ton of Water. But Full Cycle (Normal Wash) is done in just under an hour. Normal is Rinse, Prewash, Rinse, Wash, Rinse, Rinse, Rinse then Dry.
The 18-58 series are the last series that once the Motor starts, it runs through the whole cycle. The only pause is the delay for Sani Heat on the Sani Cycle.
Bada Bing... Done.
[this post was last edited: 12/23/2015-23:41]
I have a 58 with a few missing parts (casters, top...) and my 18 is in really nice shape. The racks on the 58 are in decent shape but those on the 18 look like-new. The 58 has the newer-style constant rinse, the 18 has the original one. I was lucky to get the portable for free and I found the 18 sitting in a thrift store, I got it for $40 or $50 which was a fair price considering the condition of the machine.
I'm probably going to part out the 18 built in. The 2 Portables are in great shape as you can see underneath. The 18 built in Wash Tank has a few glitches in it.
The pump was just starting to leak a bit, but the rest of the components are worthy of cataloguing and boxing. The Portables can be built in at anytime. Where as the Built in well...
Once I get Eva in, I can't wait to cook a 2 level meal on Terrence Terrace Top.
LOL.[this post was last edited: 12/23/2015-23:43]
Fantastic additions....
....and so impressive in their respective line up.
Certainly a worthwhile road trip.
Congratulations on your excellent finds. Looking forward to hearing more as they're up and running.
John
Don't forget our friend in CT!
Eddie, if the built in 18 is in good working order, why not offer it to our mutual friend who is looking to replace the KDS-17?
It will be a great upgrade to the 18.
OK.
Got a chance to start the Big Inspection the past two days.
First up... The Buzzard ( The Coppertone )
Despite the really poor appearance I think this one so far is going to turn out real good.
Filled it up with Hot Water and No Leaks.
Now, there is this God Awful mildew thing going on in the sump. So I threw some bleach on there and let it soak for about 15 minutes.
Plugged him in and he fired right up. Ran Quiet and Drained Well. However the Fan Motor for the Dry Cycle is a little screechy. So I'll lube it or replace it with one of the spares I have.
Here is the Black Slime In the Sump.
As bad as that Black Crap looks there is no corrosion around the heating element.
Now for Eva (The Avocado)
This Machine came from a "Home" with a Glade Plug in in every outlet. So, I thought the machine was well marinated in that putrid scent.
Well, I was wrong. 5 hours in the back of a open truck should have dissipated most of it.
Lookey Here...
It appears they had washed some Candle Holders or Glass Jars that had the Scented Wax in them.
I really have to say as many of you I'm sure have said in the past.. "What is the matter with people ?"
They couldn't have used this machine to wash dishes after the Candle Wash.
I ever so gently scraped as much off as I could and vacuumed the particles out.
This is a work in progress. Any one have suggestions to remove Wax from the sump ?
I'm sure this happens to almost everyone that brings home a dishwasher. (Insert a lot of Sarcasm)
"Any one have suggestions to remove Wax from the sump ?"
use very VERY hot water and some dishwasher gel...wax is a form of grease and it will melt and float to the top.  While it's floating, stick an old rag or paper towel down into the water, pull it to where it's floating and it should stick to it, then just pull it straight back up and out and throw it away.  May have to repeat a couple of times.  That should get rid of most of the wax.  A wash in HOT water at least 140F with good detergent should remove it and send it on its merry way.  My Jetclean has washed many a candle holder over the past 18 years (Tony loves candles) and I've never found any residue in the sump, and I've checked it many times over the years.  Their water wasn't hot enough and/or they didn't use enough detergent or both.  There are solvents that will dissolve wax (mineral spirits,naphtha), but I wouldn't put them in an old dishwasher, might damage the seals.
Thanks Greg.
My plan for both these guys are to Sani Cycle the heck out of them once I get the initial "DeFunking" done.
The Mildew is nasty. Again, I can't believe people used this machine. ( They Probably used it before it molded).
Tomorrow I will post pics of the Hack Job they did on the Unicouple. What the heck were they thinking ?  (Scratching Head)
"....suggestions to remove Wax from the sump ?"
Obtain a heat gun or hair dryer and a roll of paper towels.
Aim the gun at the offending wax, when some melts, blot it with a un-used section of paper towel until it's clean.
As far as removing the artificial-trailer-trash scent, I'd put vinegar in a spray bottle or garden sprayer. Spray the entire machine (avoiding <span style="text-decoration: underline;">sensitive</span> graphics and painted areas). Shake a layer of baking soda on these damp areas, then spray with vinegar again, creating a paste. Let the machine set covered in the goo over night.
Next day simply wash off with a soapy (dish soap) sponge, like you're washing a car.
This unlocks the scent. Once dry expect the smell to completely evaporate after a few days.
Good luck.
I'm needing to do general clean up with my new baby, a KDC-21AD.  It apparently works fine and has all it's bits, but has hard water build up.
Real
Dishwashers that use real water to clean your dishes CLEAN and DRY them DRY in about an hour........A Real concept considering the so called dishwashers you buy today, use NO water run 2 to 3 hours and the dishes are not nearly as clean...HMMMM!!!!I wonder which is cheaper...3 hours of electricity or 15 gallons of water......My wager would be water is cheaper than power!!!!
hans
you left out the part about the 1 year warranty and the 2-3 year longevity which means whatever micro savings in energy is eaten up in repair/replace.
