For us, the machine wasn't efficent at all by your definition.
But though it was rather resource efficent when used, it was everything but cheap when baught. It had rather big impact on the enviroment, however, that did not make it less efficent in terms of usage.
Efficent during use: Yes.
Efficent while production: Average.
Efficent during shipping: less.
Final impact on the enviroment: Bigger than usual.
You do make a perfectly true point: One SHOULD consider the whole impact, not only the efficency.
But, who should rate the impact how? I mean, one can guestimate the way through, but then companys would sue the heck out of the EU as one could argue you can't unify the impact and durability testing.
However you can unify the testing for the usage.
And, being honest, I doubt that transportation is such a tremendous difference seen what it takes to produce a washer. Just think about what it takes to produce the metal and get it into shape. Not knowing the exact numbers, but I guess if one WOULD go picking numbers about that, CO₂ emmisions for steel production would outweigh the transportation emmisions by quite a bit.
And personally I think a consumer should have enough mind about what he is buying him self. Not that I don't mean regulations are bad, but I think a consumer can weigh for him self if he is OK with a machine beimg shipped from China.
