Top load washers in the USA
WOW Paulo, you went deep in history, that great.... It's hard to see somebody that knows so much about the brazilian market. Yes, you're right about every point (we siad the same but I didn't go too deep.
Working at Prosdocimo and then Electrolux for many years, i can say, front loaders do cost much more to produce. You'd be surprised about the production costs (a washer can cost as little as $38 to be produced, depending on the model) and front loaders are more expensive.
If something goes really wrong with a Top load, it just happened. The same with a front loader has a higher chance to kill or injury somebody, that's why R&D has to be much more intense on front loaders.if it happens, it will be the worst nightmare for an engineer or a designer.
a simple testing procedure can cost up to 200.000 dollars, and i mean only one test, for example sending a prototype to Autoliv in France to be crash-tested.
Front loader prototypes have at least 50 destructive tests, while a top loader have an average of 10. in other words, it can cost 10 or 20 million dollars only to create a front loader (R&D, tests, moulds, production line, etc) while only between 3 and 5 millions to create a top loader. the manufacturer has to spend that years before the first unit is sold to a final consumer.
Of course, this is considering creating a model from scratch. Most models on the market are a spin off of previous models, that's one of the reasons washers look like the same with only a few differences.
After the product is ready to be produced, yes, front loaders are cheaper because they use fewer parts. but the difference isn't big enough to pay off the R&D costs, that one of the reasons they cost more, not only because the manufacturers are greedy.
Well, what I would like to know is what company manufactured a machine with a perforated tub that washed like the Kelvinator did? I saw a youtube of one in a different country and was kind of shocked, since it had the same agitator as the old Kelvinator and agitated the same way.
No, this was way after that. Had to have been in the 70s from the look of the machine. Seems like it was an Australian machine, but I could be wrong.
I keep seeing this trope that Americans in the 1950s simply had no concern whatsoever with what things cost or how much resources they used. But if you look at advertising from the era, it just isn't so. You'll see plenty of ads touting the cost- and resource-saving benefits of their products. If you watch the rotating PODs here, you'll see some washer ads billing their water-saving advantages -- not all of them, but a fair amount. Heck, that's why suds-savers were invented. It was especially important to people out West; if water is a problem there now, it was a lot worse in the 1950s before all of the water projects.
This applied to other products too. Most car models offered a choice of several engines, and except for high-end models there was nearly always an "economy" engine choice. Shell's gasoline advertising of the era made a huge deal out of the claim that your car would get better gas mileage on Shell gas. There were all kinds of claims for products that you could install on your car that would drastically increase gas mileage. Most of them were fraudulent, but it still shows that people were concerned about it, otherwise there would not have been a market.
Americans who were younger adults in the 1950s were ones who had grown up in the Great Depression. They learned to be thrifty, and most of them didn't suddenly change their minds just because the economy got better.
Thomas:
I'm far from surprised that some washers can cost as little as $38 to be manufactured -- in fact, if you go to Amazon, you can buy a Panda twin-tub for about $150 including shipping and handling and, the thing is, someone commented I think here in Automatic Washer that if one wants to buy a pallet with a hundred of them they cost less than $50 each.
But that just reinforces what I said, from my perspective: those machines have no transmission save for the pulleys and belts, they have large parts made of injected plastic, not a lot of labor for assembly. And given how little the design has changed in decades and that I'm willing to bet that no test to destruction was carried, *poof*, cheap machines.
Now, take a look at a very similar idea, a twin-tub by Danby, almost identical *except* that instead of an impeller, it has an agitator and consequently a transmission with gears and the whole machine is heavier. *Poof*, over $300 per item. That's a big difference, which I'm well aware it's not the difference in manufacturing costs, it might cost only about $50 more to make the transmission, but the transportation/distribution/marketing inflates that to a bigger difference for the end customer/user. And yet, a fully portable automatic top loading washer which uses an impeller can be had for less than that, but the transmission will be much simpler.
The point that you make about creating a brand new model is not lost on me. My point is slightly different: a lot of the times, when "new" appliances are introduced in US or, worse, in Brazil, what is actually happening is that Bosch, Whirlpool etc are moving entire manufacturing facilities lock, stock and barrel, to another country, in this case US or Brazil. Washer models that are over 10 years old in their original European countries, and whose manufacturing machines, tools and dies, injection molds etc were all amortized and paid for, but since the model is obsolete in Europe, they just moved the manufacturing facilities to another country and offer the model as "new" there. Just like the Philips front loader that was originally from UK but started being made in Argentina (where the power requirements were right [240V/50Hz]) and then exported to Brazil, they could cost much less, but they did not stay like that for long, as soon as the "Frigidaire" machines proved the market was receptive, they were "withdrawn", three months later same model with different brand and much more expensive price showed up.
Also, I'm willing to bet that Electrolux runs all the tests you are suggesting, but I'm not willing to bet American or Asian manufacturers do. Maybe instead of testing the entire prototype they do sub-assembly tests, or just "what the hell let's see what happens" in some in-house tests. But honestly, with all the bugs that we've seen in washers here, I have difficulties thinking that even one end user touched the product before it was released (I know that at least in Brazil, Electrolux used to go talk to users and even invited some to the labs, one of my neighbors was in the QA team and she said they used to examine complaints fully).
The other thing I wanted to say is that maybe manufacturers don't run all the tests for top loaders as they do for front loaders, but first off, those tests should have been seen as fixed costs, once they are done, it doesn't much matter if you produce two hundred thousand units or millions of units and, properly speaking, fixed costs should be amortized in 5 to 10 years, not on the first fifty thousand units. So the difference for the tests alone is that if you sell one million machines of each kind, the built-in cost for the tests is 20 bucks for the front loader but 5 bucks for the top loader, which is not that much in a machine that costs over $800. On the other hand, if the difference is on the transmission, that is a cost that re-occurs with each unit, and if each geared tranny costs $50 or $100 to make, you can't make the machine cheaper. The costs of the initial tests will approach nil if one makes 40 million washers like some models do.
Yet another point of view is that when top loaders spun at 400 rpm for delicates and 640 rpm for normal, maybe you could skip half the tests. When they are now at the 800-1100 rpm range, decent manufacturers should be running the same tests they run for the frontloaders, because the danger goes up with the forces, stresses and strain involved, and the 3 factors are linked to the spin speed, in fact some forces grow with the square of the spin speed, as opposed to everything else. We've seen some frontloaders that exploded and mostly things that were on top or the sides got affected, but when the HE impeller top loaders from Asia exploded, the *front* of the machines got affected too, that is, something at high speed could escape the confines of the washer and hurt a nearby user.
And just to press a bit more on what I'm saying, both in Brazil and US, tumble dryers, which are the machines that have the least material, number of parts and labor of all, still cost as much as the washer (front or top loader) it matches. It's pretty rare to re-design a dryer -- the design was finished 40 years ago, there might be some small changes over the decades to simplify assembly and/or make something cheaper, but the vast majority of "changes" are only cosmetic changes to make the machine match the new model year look. It's hard to find a dryer that costs less than the matching washer model. Look at dryers from a specific manufacturer, for example GE, Maytag, Whirlpool etc, and you find the same basic machine for less than $300 bucks to go with the bottom-of-the line washer and all dressed up in pretty clothes going for over $1,000 to go with the top-of-the line washer. Oh, sure, the "features" are different, the BOL doesn't have a delay timer, the MOL has a 4h delay timer, the TOL has a 12h delay timer or some simple change like that which is implemented in software anyway and can't justify 700 bucks difference *except* that they know the buyers will spring the money for the prettier dryer to match their prettier washer. Hell, people pay 300 bucks per pedestal (washer and dryer) despite the fact that now the machines are too tall to be used as a practical work surface to treat and/or fold the laundry, for example. And prior to the HE frontloaders showing up with pedestals (so people don't need to "stoop"), people were perfectly happy to use the front loading dryers anyway with no trouble. What's up with this fear of stooping people have, are they afraid someone will show up behind them and take their virginity or something? :-P
So, maybe we're in "violent agreement" here, or maybe we need to agree to disagree, but from my perspective, the logical conclusion is that the more parts and labor something has, the more it costs to *make*. How much it costs to the end user depends a lot on what the market will bear, but the manufacturers have over the decades pulled the wool over the customers' eyes over and over again, and it's not just Research & Development costs that make something expensive, as it's easy to see with tumble dryers.
And yes, in case any or you *are* wondering, I too overpaid for my dryers so they match the washers. ;-)
Cheers,
-- Paulo.
Paulo, i didn't want to enter on the "Profit factor" because that's obvious.
And yes, the $38 production cost is the cost (not the price) for an average top loader from a famous manufacturer. Of course some models cost more, others can cost even less.
If i mention the chinese ones... gosh.... the $300 chinese top load costs $10 to be produced.
But of course there are several other costs that are added to the product until it reaches the final consumer.
But, the average is 90% of the tag price going straight to somebody's pocket. It can be the manufacturer, the distributor, the retailer, etc...
I found the Kevinator orbital washer with the perforated tub on youtube. It was an Australian machine and the video was from Mayfan69. It is a 1965 machine.
Dat be it!!! Never have seen one like that before. All the ones I used to work on and use and sell were solid tub machines. In my region of the country, Oklahoma, we had a place called Otasco which stood for Oklahoma tire and supply company. In the 50's & 60's they had three brands of machines, Leonard (Kelvinator), Tempmaster (Norge) and Philco Appliances. They were plentiful in Tulsa, where I live and were as far as Missouri, Arkansas, Texas and Kansas. They sold a ton of Leonard machines back then and anyone could get credit there too, which is probably one of the reasons for their demise. Back then, if you needed appliances on credit you either went to Sears or Otasco. The field I have mentioned before of washers was much like the farm pictures that are on this site. All the trade in machines that Otasco did not have time or room to fix and resell ended up there. There were tons of Leonards, Philcos, and lots of other brands too. That is where I got machines to work on when I was a teenager and learned so much about them. There was even an old Apex like the one Robert has now. At the time, I wasn't really interested it it. Hindsight…..
Several factors
First off, suspensions are enormously more challenging for H-Axis washers than for top-loaders. The American patent situation made it super-duper expensive to sell H-Axis washers in the US with good suspensions.
This at a time when women were finally, finally freed from wringing out clothes. Anybody who has ever dealt with that knows why automatic TL washers, despite their limitations, (many, many, many as they were) became the American standard.
Second, as has been noted here - the stupid 120V limitations. 240 didn't really become common until the late 50s.
Third, and this one always upsets some of the ladies, so turn away, dears, US Americans are incredibly insular and provincial. They really believe they've got the best of everything, changing that is next door to impossible. TLs are The American Way, so we're stuck with HE shit for a very long time to come.
You ain't said nothing but a word! *LOL*
Have been sitting on the fence about either acquiring a wringer washer or Easy Spin-Drier to speed up wash days when say having to do large amounts of linens. Obvious solution would be to simply purchase a SQ or other uber sized front loader that could handle more than the Miele or AEG in one go, and do things faster.
Having done large amounts of linens in a tub using a mangle to get some of the water out before they go into either spin dryer or one of the automatics for a final rinse and then spin, yes am here to tell you can see how using a wringer would get old fast.
Granted mine are only hand powered but still... having to ensure things are spread properly along the rollers but kept away from the ends/bearings (where grease lurks)is more than one cares to bother with after the first few things.
Small items are fine, but larger such as sheets and blankets wear one out.
Yes, one knows.....
But have no room for another automatic washing machine.
Between the Miele and AEG that is it far as space wise for automatic washers. One would have to go and am not ready to put the former out to pasture, and the latter is only a few years in service and was nearly new when purchased.
