Tub banging sides- what causes it?
Floating tub suspensions are usually paired with higher speed spins.
They are (probably) somewhat cheaper than other suspension designs, but from a purely engineering standpoint, low vibration at high spin speeds is the goal.
With an unbalanced load spinning, the tub is constantly changing direction.
A change in direction always means a kind of acceleration (not in the "go faster" sense, but in the physics sense).
As the tub spins slow, there is more time of the tub traveling in the same approximate direction.
As it speeds up, there is less time for the tub to travel in that direction.
The mass of the tub stays the same.
Force is mass times acceleration.
That means that at lower speed, the force is less (the tub has more time to change direction, so acceleration is less) but the tub has a lot of time to travel in a general direction.
That means the amplitude if travel is larger.
If an OOB system isn't fast enough to respond, that can lead to the tub hitting the cabinet.
However, at higher speeds, the tub has to change direction quicker - acceleration goes up.
That means force goes up.
BUT at some point the tub is changing direction so fast it simply has no time to travel enough into a specific direction to make contact with the cabinet.
Now, on the cabinet side, any force transmitted into it makes the cabinet move a bit. Any force always requires equal opposite force, and that opposite force results in movement in the cabinet.
And movement in the cabinet is vibration which is generally a big source of noise during high speed spins.
(You'll see the cabinet, despite being very "thin" does not move much.)
So, if the suspension is "soft" (aka low resistance) any force on the cabinet side can only get so big. Thus, vibration stays low.
And when forces get high (high spin speeds) you need to limit any force as much as possible.
The most extreme example is commercial hard mount washers.
You can just not have any movement at all. But the forces have to go somewhere. And that's a massive concrete slab in that case.
You can create very high spin speed machines that way aswell (see Milnor) - but why should you?
These TLs are the opposite - they use basically maximum movement. That allows to get very high spin speed with minimal opposite force.
But the danger is that maximum movement leads to "physical interference" - aka collision between tub and cabinet.
That should in theory be offset by OOB sensing - but that has it's limits as well...
@henene4:​
The tub banging gets worse toward the end of the video as the machine's spin speed increases.
You're not wrong in a typical sense, but there is something else going on with this machine in the video.
Speed Queen spins at 810 rpm and vibrates less than a hinging suspension machine.
I did not watch the video past 2min that is correct.
But the motor does cut out at that point.
That almost looks like some weird resonance happening there - but it also does collide in the early ramp up phase.
And the TC5 spins at 710.
The TRs do spin at 820 - but they have a variable speed motor, with an inverter - and thus most likely OOB sensing & control.
BTW don't EVER do what they are doing towards the end there.
Don't ever try to stop the tub from moving with your hand.
You do NOT have the strength in your hand to stop 40lbs or so moving at that speed.
All that's gonna happen is your hand being crushed or your skin being ripped by any sharp point.
