Tub seal & possibly bearing gone. A606
Cloth into agitator
"you stuff cloth in the agitator to keep the hot water to stay in the agitator base (skirt)? Was it boiling water and how much water did you use to fill the tub? "
I used boiling water in a tea kettle, it doesn't take much to fill the inside of a maytag agitator. I didn't fill the tub. I went thru about 5 tea kettles worth. But it dispenses easily from a teakettle vs a 2 qt revereware pot.
I had an old stafford Tshirt I ripped into strips. The cotton swelled nicely after the 1st batch of hot water and the leakage slowed down to just dripping.
The bike inner tube I cut into so it had the inflator at one end, and a long 86" handing down from that. Twist, fold and seal with cable ties at each end. I then wrapped the innertube around under the agitator about 4 times, then inflated it. It took a few tries, the innertube kept popping out from under and bulging horribly. I never got above 15 psi or so in the innertube. But as you see it eventually worked.
fltcoils...
"The bike inner tube I cut into so it had the inflator at one end, and a long 86" handing down from that."...WHERE did you cut into the inner tube...WHAT is a 86" handing..."twist, fold and seal with cable ties at each end"...WHAT are cable ties...HOW and WHAT exactly did you do to tie the ends?
What type of inflator did you use...I know there are different kinds, do I need a specific one? I priced a couple today, one for $20, another for $45...I DON'T want spend alot of money for the inflator pump if don't have to.
But, MOST IMPORTANTLY, can you PLEASE post demostration pictures so we can see in detail how everything looks?
It's kind of hard to visualize how to prepare the inner tube and the inflator pump. I want to be able to handle this correctly so I can also be successful removing my agitator. I've had my Maytag A712 about a month now...I'm ready to pull this thing off.
home made agitator extractor
take a bike innertube, I used a 27 x 1 7/8 tube
Cut across the tube about 1-2" from the schrader valve (inflator valve). Fold the cut ends of the inner tube onto itself with one to two twists. GEt a zip tie/cable tie from Lowes in the electrical section, they'll know what it is. Wrap that around the twisted folded end of the inner tube. Zip the tie tight.
You now have a 86" long haaannngggiiiinnnggg inflater tube. The snake has a schrader valve at one end for inflating, use a bike pump to inflate it.
IN the pic
UL corner, arrow points to bike pump used to inflate innertube.
LL corner, left to right arrows
- cable tie/zip tie wrapped around folded twisted end of inner tube
- schrader valve of innertube
- bike pump connector
Wrap this, still uninflated snake around the base of the agitator 4 or 5 times, inflator end last so you can inflate it. slowly inflate it. 10-15 psi will produce visible results.
[this post was last edited: 4/29/2010-16:16]
