Jim, you've got a beautiful machine there! The wash looked great, both spin and pulsation. Your tub appears to be in beautiful shape!
Question about your machine. If you read up in the Tech Talk's about the 56 Imperial machine, there was a bulletin published in regards to the timer dial having not been printed correctly. My machine will go into the first spin when the indicator shows it should be starting the overflow wash, and stops spinning when it gets to the first spin. It really is funny because the end of complete wash cycle is exactly where the end of dry is. I was wondering if the alignment was more accurate on your machine as they did correct this on the later machines. I noticed your machine had a nylon water valve so I was curious if it was later.
Thanks for posting these great shots!
Ben
