Unusual grime/Lindt left on my laundry after using brandt
adam-aussie-vac
Dec 14, 2017
1,052
Canberra ACT
Hey guys, so I’m not sure what it is it might be Lint or it might be dirt, What am I looking at? I did a mixed load consisting of one dressing gown one towel pants shirts underwear socks, and this is what seems to be showing up, and it was all over on the inside of the machines lead as well so I’m not sure if it’s coming off the laundry all the machine as the machine looked fine beforehand, Should I re-wash should I chuck it in the dryer and see if it just comes off? After having a look at it closely I think it’s just Lint so it should be okay in the dryer
That`s correct there`s no reference to any sources in the Wikipedia articles but this does not necessarily mean it`s all made up. Well, it might not be 100% accurate.
The German technical term of "Fatlice" (translated word by word) is well established by Henkel and Miele just to name a few.
What is new to me is the destructive impact on aluminum spiders which makes perfect sense to me. I`m not a biologist but I can very well imagine that the bacteria in a moist biofilm in a washer makes an acidic environment just like the plaque on teeth does. Aluminum is attacked by acids, isn`t? Don`t need any references to believe this.
On Fettläuse in general I can gladly share more reputable sources than Wikipedia.
https://www.merkur.de/leben/wohnen/...alttipps-fettlaeuse-kleidung-zr-91950644.html
https://www.t-online.de/heim-garten...gelnde-hygiene-durch-fehler-beim-waschen.html
Scrud would generally be a buildup of biofilm containing fabric softener fats and bacteria. Fisher and Paykel used to have a page on the explanation because the hot eco active rather than a hot deep fill could cause it to occur.
I second doing a hot wash with the detergent tablets at 90 and then cleaning the bits above the water line. I’d use it only for towels until the buildup goes away.
Being in Australia it’s highly likely that it was mainly used with cold only washes.
So it left a small amount of residue,
But I decided to immediately wash everything that went through that machine in hot water with my GE, and that apparently looks like it got rid of it all after giving everything a thorough look over that was washed in that machine, I’m gonna pick up some washing machine cleaner [my preferred brand “Dr. Beckmans“] as it’ll allow me to do a very very hot wash on 90, I might decide to even take the outer shell off that way I can clean every fold of the Bellows I’ll try using that nifti brand Of cleaner as I found that to always do a really good job with most things
I think the English term is 'grease balls'.
I've seen it in a Hoover twin-tub, where the dirt formed small floating spheres of greasy, dust-laden bubbles. There wasn't enough detergent in solution, the water was too cool, and the items were also too dusty in the first place.
I've also seen washing machine manufacturers refer to it in the user instructions.
Also, modern machines have in some cases, been hobbled by very low water levels - especially where they don't have a high water level option. Any dirt including grease, lint and so on, simply gets floated above the low water level's maximum mark. And stays there. My Panasonic front loader is like this. Lint is problematic. It doesn't have a tub cleaning programme.
Some machines might have a decently hot 'tub cleaning' programme. Others simply splash around at 40°C. Too cold and does nothing. My first Panasonic was like that.
Machines which do 'spin washing' should largely be self cleaning.
With my machine, I have to put it on the 90°C Cottons programme, with 'Dr Beckmann's Power Descaler' - which is malic acid crystals.
When temperature is reached, I switch off and restart again. The machine does the initial 'distribution speed' mixing procedure again - but now with the scalding water in the tub. I usually repeat this several times, then I add a few more litres of water via the dispenser drawer and let it get back up to 90°C.
The water level has a few 'sweet spots'... maximum agitation is when the water level is below the inner drum lip; water levels above that switch to reduced agitation. Raising the water level higher still usually activates the 'suds reduction sequence', or overfill detection drainage.
I managed a couple of times, to add a few extra litres whilst it was reheating back up to 90 degrees. Normally it would try to add cold water to cool down before draining. It reheated a bit then went into pumping scalding solution straight down the drain with no cooling.
To rinse the tub, I repeat the normal Cottons programme from the start with cold water, adding a few jugs of water and restarting several times, getting the machine to do the distribution churning each time, then I manually progress it to static drain.
The above carry-on works for me - just - but would completely piss off a hell of a lot of folk, who simply don't have time for farting about.
Oh OK, so I guess that means I didn’t really
Use enough detergent, I guess and the reason as to why because at the time I was trying to make sure that I don’t have suds spilling out the sides because the seal doesn’t really work on that machine but apart from that nothing really ever comes out of it, I did run some Dr. Beckman‘s washing machine cleaner but I haven’t used that machine for Laundry yet but I’ll probably do a bit of laundry later tonight or tomorrow
Hi Adam
what does the residue feel like? Rub some of it between your fingers.
If it just feels greasy / slimy, then it is probably just buildup of body fats and general yuckiness. If you did a 60 degrees C wash in a machine that had done cold washes for years (by previous owner) then you may have loosened up some big deposits of nasty stuff. A few more hot washes should clean all that out.
But if the deposits feel like they are gritty and metallic, it could be the bearing mounts / axle supports on each side of the drum are breaking up. That is what happened on  my dead one. Also caused by cold water washing over years. They are cast aluminium.
Oh GREAT!
An engaging post about SCRUD.
We learn something new everyday.
I was going to suggest that hard water deposits that can accumulate on the outside of the basket had come loose and implanted themselves on the clothes because there was not enough detergent to keep it from settling.
I think those dark spots on the lid of the washer in reply #1 rule out anything gritty like loosened hard water deposits, lint or zeolite residue.
While the hotter the better is true to get out greasy stains from clothes a hot wash can`t do much about to keep dissolved grease and oils in suspension if the detergent has been underdosed. There are limits to Sinner`s Circle.
Even if the detergent is just about enough to keep oils suspended during the wash a grease laden load might still result in the formation of grease balls during the rinses. Even more so if FS is used.
I`m always alarmed if I don`t see any suds in the rinses. The only exception would be if I used a zero suds detergent or natural soap to begin with which I don`t.
But most likely you`ve done everything right and there`s just a nasty build up in the washer from previous owner.
