Unusual grime/Lindt left on my laundry after using brandt
The thing is I actually haven’t used this Machine
In quite a long time and they didn’t really feel greasy, they felt slightly Linty and a little greasy , That was probably my fourth wash with it since I took it out of storage, and I’ve always done hot washes with it, It’s just something I’ve always done and I’ve had that machine since probably 2019 I think or 2018 I’m not actually sure
I did a load of towels in it that mom hung out,
She said that she didn’t have any problems with it so I’ll actually do my laundry tomorrow on a 60° wash, I think it was a case of underdosing the detergent, at the moment now I’m just filling up the detergent stuff until the max lines are reached on the windows of the detergent holders
And also to update the situation
It has finally been resolved, and I no longer have any sort of biofilm ending up on my laundry, although I probably did end up using too much detergent as I ended up running two extra rinses until the water came out clear and then I let it finish with the fabric softener so I’ll probably use a scoop that is about 1 1/2 inches wide by 1 inch wide for my detergent although I probably used too much detergent but I rinsed it all out,
On a related note I have two horizontal axis machines, one does spin the other one rinses a lot, or should I use the same amount of detergent for the main wash? Or should I change it varying on the amount of water that I use for the main wash?
