filterflo
Working on the Westinghouse Programmed Computer. Most of all the rubber was bad, some of which I had replacements for and some of which I had to make other pieces fit. Got it running pretty well for just a few minutes, then CLANK CLANK! Seems there were a couple of coins that worked their way into the pump! Opened it up, removed them. Its running again when just a few minutes later: CLANK CLANK CLANK again, and MORE coins! It was kind of like hitting the jackpot on a slot machine, only a lot more trouble to pick up the winnings. Finally removed the drum vanes, and the sump was just loaded with coins and pins and nails, and chains and JUNK!. There was so much gunk caught in it I thought it best to replace it rather than clean and reinstall the old one.
