Venus, guess whats cookin' tonite?
changing tastes
"Well, I'm thinking Austin is probably just expressing himself right now food-wise, in a few years he will probably feel entirely differently about company chicken and things like that. :)"
I've had complete reversals in taste from childhood to adulthood. HATED seafood as a child, now I love it, especially since I found out that frying it in cornmeal the way my family did it wasn't the only way it could be cooked. I liked tomatoes and pickles as a child, now I'm just now starting to like (raw) tomatoes again and I still hate pickles as an adult. And with the tomato thing, it's only RAW tomatoes I didn't like. Tomato soup, stewed tomatoes, salsa, tomato juice were all devoured.
Picky , picky, picky...
Jaune:
Yes, I know what you mean about a "maturing palate". I used to detest green beans. Now I cook them with diced bacon, onion, chicken broth, and lots of pepper. Wow, they taste great that way. However, the one thing I still can't stand is BEETS. Yuk! To me they have always tasted like metal >:[
Hopefully when the kids get older everything will balance out.
Thanks for that hint Venus, I love green beans but have never thought of using chicken broth to cook them in. I will give that a try. Terry
Lovin/hatin food
Green beans are great if you don't overcook to khaki green, so is broccoli. I used to hate spinach as a kid, so my father used to mix them into mashed potatos (hence, green mashed potatos) & I loved em. I grew to like spinach, & I'll even eat Boston Market's version of creamed spinach.
Beets are good pickled, or with butter
Pickles I've never been fond of (Dill), until I tried half-sours, which have garlic in them & are much greener
(I can eat 1/2 a jar in one shot, though no kissing!)
One thing I detested as a child was cottage cheese, but dorm food cured me of that.
Jerry
I used to make my own chicken broth.I love using Campbell's chicken broth or Swanson's broth in making many recipes.White rice cooked in chicken broth is delicious.
For a canned broth, Campbell's makes a pretty good one.IMO it is far better tasting than College Inn.
1946 pressure cooker
As a teenager digging through the cupboards (this was mid-70's), I found Mom's old pressure cooker. Don't recall her ever using it, but somehow I managed to get it into my 'pile' when divvying up the household years later... it's a "During Scale-O-Matic," with a copyright date of 1946 on the owner's manual/cookbook. The lid has a cantilevered arm with a weight which slides up and down this arm for 5-10-15 lb. Still going strong... used it about a month ago to cook beans. Solid die cast aluminum.
1946 Pressure Cooker
Wow, I love to hear about someone who appreciates vintage small appliances. Those pressure cookers will probably outlast all of us. About the only things that could go wrong on them are the rubber gaskets or losing the regulator (if it isn't permantly affixed).
Enjoy your pressure cooker like we do (but watch out for exploding beef stew ;-); one of my previous experiences).
I assume the gasket was still soft and pliable? I imagine it might be hard to find a replacement gasket for it, and that's a critical part.
First outing of Princess Digital pressure cooker
So today I inaugurated my Princess Digital pressure cooker. I've had it over a year, so with all this discussion and recipe swapping, I figured it was time.
The unit is electric, but has an inner pot (its set up like a rice cooker) that can be removed and used as a regular pot or a manual pressure cooker ontop of the range. When as an electrical unit, you put the ingrediants in, set one of 2 pressures on touchpad, then time (1 minute to 4 1/2 hours), then start. It doesn't start counting down time until it comes up to pressure, then switches to a keep warm setting. It cn also be used as a slow cooker for up to 4 1/2 hours. There are 3 cooking heats for browning, simmering, etc. Timer can be used with pressure or regular cookingComes with a spring form, metal rack, glass cover, steamer basket, wire basket with handle.
Would you believe it uses the same power cord as comoputer.
So here's the inaugural recipe, from Lora Sass's The Pressured Cook
For you Southern folk
LOUISIANA BLACK-EYED PEAS AND ANDOUILLE AND COLLARDS
1 lb collard greens
1/2 to 1 lb andouille or other spicy smoked sausage, cunt into 1/2 slices
2-3 tbs olive oil (optional)
1 1/2 cups chopped onions
4 cups water
2 cups black-eyed peas, rinsed and picked over
2 large bay leaves
2 teaspoons sweet paprika
2 large ribs celery, coarsley chopped
2 large cloves garlic, pushed through press
1/2 tsp dried thyme leaves
salt and freshly ground black pepper to taste.
2-3 tbs apple cider vinegar
2 large red bell pepers, roasted, seeded, and cut into 1/2 squares (I just chopped up a green pepper and threw it in with the chopped onion, more work than I wanted to do)
chopped fresh parsley for garnish
Hold the collards in a bunch on a chopping board. Trim off and discard the bottom inchor so of stems. Thinly slice the stems. Stack 3-4 of the leaves and cut into thirds lengthwise. Cut as thinly as possible crosswise. Repeat with the remaining leaves. Swish the chopped collards in a large bowl of water. Drain in a large colander and set aside. (Again, too much work. I just used the already packaged collard greens)
Lightly brown the sausage in the cooker, about a minute on each side. Add oil, if needed, to prevent sticking. Add the onions (onion/bell pepper mix, in my case) and cook, stirring constantly, 1 minute. Add the water and scrape up any browned bits sticking to the bottom of the cooker. Add the black-eyed peas, bay leaves, and paprika. Set the celery and collards on top. (Don't be concerned that the cooker will be filled beyond the recommended maximum capacity; the collards will shrink dramatically as the cooker comes up to pressure.)
Lock the lid in place. Over high heat, bring to high pressure. Lower the heat to maintain high pressure and cook for 10 minutes. Quick-release the pressure by setting the cooker under cold running water (with electric pressure cookers, can only do this step if controls are removeable, or has inner pot system).
Stir the stew well to distribute the collards. Add 1/2 water if the mixture seems dry. Remove the bay leaves and add the garlic, thyme, salt, & pepper. Perk up the flavors with the vinegar and simmer, uncovered, over medium heat until the black-eyed peas are tender and teh garlic loses its raw taste, about 3 minutes. Stir in the roasted red pepper. Serve by itself or over rice. Garnish the serving bowl or individual portions with parsley.
http://www.great-values-online.com/store/CookingSmallAppliances/1238634.asp
thank you Jaune
And everyone else for contributing pressure recipes-woo! We are all getting quite a collection now. Like many of you, I'm a novice at pressure cooking. I love it, but wished I had sprinted for a six quart. Well there's no law saying you can't have 2 cookers; we have 3 crockpots (one in each size).
Jaune - What a chef!! :-)
Jaune:
This really sounds good! I would certainly serve this with some cornbread and strawberry shortcake for dessert.
A good meal doesn't have to be fattening or complicated. I think that I will invest in a copy of Lorna Sass's book.
Venus
Next pressure cooker recipe
"The Ultimate Pressure Cooker Cookbook"
Tom Lacalamita
Simon & Schuster 1997
ISBN 0-684-82496-5
This one is for Hannibal Lecter
FAVA BEANS WITH CURED HAM
1/4 olive oil1 large onion, chopped
1 clove garlc, peeled and minced
4 oz slice Italiann prosciutto, Portuguese presunto, or Spanish jamon serrano, cut into 1/4 dice
3 lbs. Fava beans, shelled
1/2 tsp salt
1/8 tsp freshly ground black pepper
3/4 water
1/4 minced parsley
Heat the olive oil in the pressure cooker over medium high heat. Add the onion, garlic, and ham. Saute 4-5 minutes or until onion is soft. Stir frequently so that the onion doesn't brown. Add the fava beans, salt, pepper, and water.
Position the lid and lock in place. Raise the heat to high and bring to high pressure. Adjust the heat to stabilize the pressure and cook 7 minutes. Remove from the heat and lower the pressure using the cold-water-release method. Open the pressure cooker, taste, and adjust for salt and pepper. Stir in the parsley before serving.
So many Texans
Since there seems to be so manyof you in Texas, here's a slow cooker recipe for y'all.
Easy Home Cooking Slow Cooker Recipes
Publications International Ltd. 1997
ISBN: 0-7853-2390-2
TEXAS STYLE BARBECUED BRISKET
1 beef brisket (3-4 pounds) cuti into halves if necessary to fit slow cooker
3 tbs worcestershire sauce
1 tbs chili poweder
1 tsp clery salt
1 tsp black pepper
1 tsp liquid smoke
2 cloves garlic, minced
2 bay leaves
Barbecue Sauce (I suppose you could either use your own or make theirs, recipe follows)
Trim excess fat from meat and discard. Place meat in resealable plastice food storage bag. Combine worcestshire sauce, chili powder, celery salt, pepper, liquid smoke, garlic, and bay leaves in small bowl. Spread mixture on all sides of meat. Seal bag. Refrigerate 24 hours.
Place meat and marinade in slow cooker. Cover adn cook on LOW 7 hours. Meanwhile, prepare Barbecue sauce.
BARBECUE SAUCE
2 tbs vegetable oil
1 medium onion, chopped
1 cup ketchup
1/2 cup molasses
1/4 cup cider vinegar
2 tsp chili powder
1/2 tsp dry mustard
Heat oil in medium saucepan over medium heat. Add onion and garlic; cook until onion is tender. Add remaining ingrediants. Simmer 5 minutes
Remove meat from slow cooker and pour juices into 2 cup measure; let stand 5 minutes. Skim fat from juices. Remove and discard bay leaves. Stir 1 cup of defatted juices into Barbecue sauce. Discard remaining juices. Return meat to slow cooker. Cover and cook 1 hour or until meat is fork-tender. Remove meat to cutting board. Cut across grain into 1/4 inch thick slices. Serve 2-3 tablespoons Barbecue Sauce over each serving.
Wednesday Night's Dinner...
Tom snapped a pic of tonight's meal, courtesy of my 1950 Betty Crocker cookbook. We dined on broiled chicken, mashed potatoes, and Creole green beans. I have to admit, it was pretty darned good! :-)
I think I'll just roll myself down the hall now (groan).
Wow, I somehow missed that Texas BBQ recipe. I LOVE brisket.
BTW, Venus, make your pics just a touch larger, I can't get a good view of those vittles and I'm in need of supper. ;-)
Another Pressure cooker recipe
Pressure Cooking Anytime (In No Time At All)
Copyright 1977 by Mirro Aluminum Company
Published by Golden Press, New York
Library Of Congress Catalog Number 77-77927
These recipes seem to be set up for Mirro "jiggle type" pressure cookers, but I lm sure they can be adapted to other types and brands.
As a matter of fact, if anybody has one of these type of pressure cookers and wants this book, they can have it for cost of postage. First come, first served. I have several other books that aren't brand-specific, so I wouldn't miss it.
POACHED TURKEY BREAST
1/2 turkey breast (about 3 pounds)
2 cups water
1 tsp salt
3 large onions, cut into wedges
2 stalks celery, with leafy tops
3 sprigs parsley
2 carrots, scraped
sauce
1. Place turkey breast in cooker, meaty side down. Add water and remaining ingrediants except sauce.
2. cover, set control to 10 and place over high heat until control starts jiggles. Reduce heat and cook 25 minutes (or cook at 15 for 20 minutes).
3. Remove from heat and let cool 5 minutes; then run cold water over the cooker to finish reducing pressure.
4. Remove turkey to platter; slice. Reserave borth to make sauce.
Serves 4-6 (4-8 quart cooker
A 3 pound turkey breast half can be cooked in a 2 12 quart cooker providing there is at least a 1 inch space between the meat and the top of the cooker.
SAUCE
Turkey broth
2 tbs sherry
2 tsp soy sauce
2 tbs cornstarch
1. Strain broth and return to cooker. Reserve carrots and slice.
2. Mix Sherry, soy sauce, & cornstarch to make a paste. Add to broth and cook, stirring, until thickened and clear. Add carrots and heat. Pour sauce over turkey on platter.
Lorna Sass Book
Venus, did you ever get the Lorna Sass book you ordered? If so, did you try anything out in it?
Wild Rice with Sour Cream and Mushrooms, a side dish
Took this to my book club on April 2, and I had one spoonful of leftovers!
1 cup wild rice, rinsed and drained
4 cups water
1 TABLESPOON mild oil (I usually use Mazola)
1 teaspoon salt.
Pressure cooker, 25 minutes at 15 lbs, quick release.
While rice is cooking, saute 2 medium onions, coarsely chopped in 2-3 tablespoons REAL butter. When they are beginning to brown, add 2-3 cloves of garlic, thinly sliced. Remove to a clean dish-- (I used my Corning French White 2 quart oval)
Clean and slice 8 ounces of fresh mushrooms, and saute in same pan with additional butter. When browned nicely on both sides, remove to dish. If there is any butter left in the pan, fry a slice of bread and have a cook's treat!
By this time, the rice should be done, or nearly so. Release pressure quickly-- cold water, or the lever, if you have the lever.
Drain rice in strainer, and add to mushrooms and onions.
Stir in 1- 1 3/4 cups Sour Cream, regular or reduced fat (Not the Nonfat!!--Never!!!)
Adjust salt and pepper as needed.
Cover, and let sit in a 350 F oven until ready to serve, or until your book group ride shows up. Or about 15 minutes.
Serves 4-6 hungry people, OR 2-4 really hungry people.
(My sister in Minnesota sends me wild rice, and everything else was in my pantry.)
wild rice
Your sister sends you wild rice from Minnesota? Is the sale of wild rice not allowed in Ohio? :-)
Does that wild rice side dish sound good. Will have to make it this week while my sister and brother-in-law are visiting from Orlando.
PC recipes are the greatest!
Lawrence:
That wild rice recipe sounds wonderful! I just have to figure out a way to disguise the mushrooms from my husband! LOL
Jaune:
Yes, I did receive "The Pressured Cook". I have been using some of my vintage cookbooks the last couple of weeks, but plan on making Chuckwagon Beef Stew with Smashed Potatoes this week. It's a really nice book with some tasty sounding recipes. My only regret is that there are only so many meals that one can make in a day! :-(
Jaune--
Wild rice is for sale in Ohio...but is better priced in Minnesota!
Venus- dice the mushrooms, call them "Chinese Evergreens!" (That's what Grandma Prichard called them) Or, slice them large, and pick them out of his portion. Better you cooking for Tom than me!
Love and laughter!
Lawrence/Maytagbear
Diverging
This is a Slow Cooker recipe for seafood fans.
The 150 Best Slow Cooker Recipes
Judith Finlayson 2001
Publisher: Robert Rose (Canada)
ISBN 0-7788-0038-5 (USA paperback)
SNAPPER VERA CRUZ
Feel free to use any firm white fish instead of snapper
1 tbsp vegetable oil
1 medium onion
1/2 tsp dried oregano leaves
1/4 tsp ground cinnamon
1-2 jalapeno peppers, finely chopped
1 28 oz. can tomatoes, drained & chopped
1/2 cup fish stock or clam juice
1 lb snapper fillets, cut in half length-wise and sliced as thinly as possible on the horizontal
2 tbsp lemon juice
1 tbsp drained capers
10 olives, pitted and thinly sliced
hot tortillas (optional)
1. In a skillet, heat oil over medium heat. Add onions and cook, stirring, until softened. Add garlic, oregano, cinnamon, cloves, and jalapeno peppers and cook, stirring for 1 minute. Add tomatoes and stock or clam juice and brinig to a boil.
2. Transfer mixture to slow cooker stoneware. Cover and cook on LOW for 6-8 hours or HIGH for 3-4 hours, until hot and bubbling. Stir in fish and lemon juice. Cover and cook on HIGH for 20 minutes or unti fish is cooked through. Stir in capers and pour mixture onto a deep platter. Garnish with olives and serve.
Cooking Under Pressure
You may want to check out this forum on yahoo,Cooking Under Pressure, they're quite helpful.
I have two, the old aluminum Presto with jiggler and a newer TFal stainless with pressure settings and quick release. If you're the beef stew or chili type person I am, once you get one of these you'll probably end up stowing the slo cooker way in the back of the cupboard. Why. because in the time it takes to brown the meat, then peel and chop the veggies only to let the sit in a slow cooker, you can do the same peeling and chopping then throw it in the PC and be eating it in about 10-15 minutes including the heat up time. Honestly I think the stew in PC tastes better than the slo cooker method which tends to make all the veggies saturated and taste the same. Another good reason for having one is that you can use it as a regular pot anyways, so no loss there.. The T-Fal comes with two lids,,the pressure lid and a normal non pressure lid but with a vent built into the knob for adjustments, plus the little basket for steaming.
Critical to using them though is to reduce the heat and start timing as soon as it starts to vent, you should reduce it to the point that little steam is escaping, or the jiggler is just barely rocking.
slow cooker/pressure cooker
I use both quite often. Often I'll prepare the ingredients for a recipe for both at the same time since I'll have the food processor already out. That way I'll have something different to eat for the next couple of days.
PS recipe
Pressure Cookery Perfected
Roy Andres DeGroot
1978
Summit Books, NY (division of Simon & Schuster)
ISBN 0-671-40006-1 (bound)
0-671-40038-X (paperback)
QUICK NEW ORLEANS CREOLE JAMBALAYA
Requires 6 qt cooker
Cook under pressure at 10 pounds for 6 minutes (or 15 pounds for 5 minutes)
About 3 tbs bacon, ham, or other pork fat
3/4 lb lean boiled ham, dieced into large pieces
3/4 lb slightly peppery sausages, cut into 1/2 rounds
3 medium onions, peeled and chopped
1 lb can Italian peeled plm tomatoes
2 green(bell) peppers, cored and chopped
2 stalks celery with leaves, chopped
6 oz can Italian tomato paste
1 1/2 cups long grain rice
2 cloves finely minced garlic
1/3 cup fresh parsley, chopped
3 tbs fresh thyme, or 1 tsp dried
3 whole bay leaves
salt to taste
freshly ground black pepper, to taste
red cayenne pepper, to taste
3 cups chicken bouillon
3/4 lb sea scallops, in bite-size pieces
3/4 lb boiled, shelled shrimp
Saute ham and sausage until lightly browned, about 3-4 minutes.
Add chopped onions and continue sauteing until they are transparent and wilted. Now toss in tomatoes, green peppers, celery, and tomato paste, letting it all bubble hard to boil off some of the excess water. When the sauce shows the first signs of thickening, mix in the rice, garlic, parsley, thyme, bay leaves, slat, pepper, and cayenne to taste. Stir in 2 1/2 cups of the bouillon. Put on lid, bring pressure up to 10 pounds for 6 minutes (15 pounds for 5 minutes). When timer rings, turn of heat and reduce the pressure immediately. When you open the lid, most of the liquid should have been absorbed by the rice, which should now be edibly soft. (if not, add the remaining 1/2 cup of bouillon and continue cooking, covered, for a few minutes longer, but not necessarily under pressure.) Using a wooden spoon and working gently, with lifting rather than stirring strokes, fold into the rice the scallops and shrip, evenly distributed. Heat them up for 4-5 minutes by letting the remaining bouillon gently simmer, open over low heat. Then serve at once in hot bowls.
Sounds great, Jaune--
There is no reason why that recipe for the quick jambalaya couldn't be cut in half-- for use in a 4 quart cooker. (I do it all the time.)
I had NO idea that R A de Groot had written for the pressure cooker. His other recipes have always worked well for me, and are flavourful and well balanced.
Thanks for posting it.
Lawrence/Maytagbear
