Very Pretty in Pink!
Hey Dave,
CONGRATS on getting that awesome Spacemate set... and in PINK no less!   They look to be in incredible condition!
I look forward to reading reports on how they function!
YAY!
Kevin
Those are VERY NICE
It appears to be a "weigh to save " indicator on the right side of the buttons on the Laundramat. Is that possible?
Hope you do a video or two... and secondary controls "close up" Mr DeMille !!!
I'm looking for a Westinghouse like crazy!
Wow congrats!
I saw 3 or 4 machines like this here in my city
Can you get a close-up of the timer and buttons?
What style of motor this washer uses? (High speed motor like Bendix?)
Any information is appreciated.
Thanks
Rodrigo
Congratulations Sudslock!!
Frontaload:
There is no way to weigh-to-save with a side swing door, but you are right that it is an adjustable water level selector.
The main disadvantage with these machines is that like with the first Bendix machines, the water sprays into the top of the outer tub and onto the outside of the rotating cylinder, not into the cylinder and directly onto the tumbling load like with the full-size WH washers so the first flush rinse is not as effective at actually flushing water through the load.
Weigh to Save
I think you're actually seeing the metal model tag by the door. The pic was taken at angle to it is hard to tell. I too thought about that for a sec.
-Tim
Rodrigo, all Westinghouse were single speed 1725rpm induction motors. Earlier ones had a 'transmission' and later ones had tumble and spin pulleys with a one-way clutch between them so that in spin the spin pulley simply overran the tumble pulley.
To Dave-"Sudslock1"
Hi Dave!
I wish you LOADS of LAUNDRY with your new "Space-Mates"! It's funny, those were two of the only few front-load machines I never watched in operation. I sure hope you will consider making a video if at all possible, of those beauties at work!
Jason
Stacking Spacemates
I noticed that the dryer is flipped over when stacked on top of the washer. Are the dryer controls easily "reoriented"? I noticed also this way both dryer and washers door will swing out the same way (hinge on the right side) Which is a safer arrangement in a stacked installation. Side by side the washer should be installed to the left of the dryer. Most top loaders are designed have the dryer to the right of the washer. I never noticed this topic discussed before.
