Victorian Chickering Upright Piano
New hammer shanks. To me, anything that was worn in the action such as the rollers, backchecks, any felt, etc., needed to be repalced. In my case the springs, and bushings were in great shape so I didn't replace the whippens/escapments/repitition levers.
Jig I made to set the various measurements of hammer travel/letoff etc. That cardboard in front is the height of the strings in relation to the keybed. That is how I set the jig. No, I didn't forget to felt the other key ends (green felt) - there ain't no dampers at the high treble strings.
Prior to installing the finished plate and anything else, it was time to make the necessary cuts in the keybed for the later addition of the MIDI player guts. Three Hundred pound case laid upside-down to cut the slot.
Guide rails for the saw. Again, the measurements for this had to be done from the top then transposed (or whatever) onto the bottom. I had to made alterations to the keyframe, (cutting off the back inch and a half), the key blocks which will now do all of the alignment of the keybed/action since cutting this slot resulted in the back guides being eliminated. I'm not including all of those pictures as it doesn't pertain to a "rebuild". I did want to show this however, and you'll see that the slot runs right through the area that the pedals attach - so I will have to invent new trap work for those to be operable.
The rail for the player mechanism is allegadley supposed to be enough to compensate for the loss of the structure after cutting the slot according to the manufacturer - but I'm kinda of a "overbuild" kinda guy so I routed out an area for a 1/4 inch steel angle iron to be laid.
I only have one "tied" treble string. The first one. I did tie this myself after much practice. The rest of the strings loop around the hitch pin and head back up to another tuning pin.
Then it's just a matter of pounding in all of those pins stretching the strings as you progress with a string stretcher (for real), and bringing up the tension. The towel serves to silence the strings while you're banging on the pins - you don't need to listen to THAT too! While you add strings you have to weave in that string cloth. Some piano makers didn't use it, saying that the length of string from hitch pin to soundboard bridge added "color". Chickering silenced that portion of the string with that cloth.
