Yeah, so another year goes by and he does nothing....
So I'm having a house guest in a couple weeks and I decided, what with our hot weather and all, that I would try to get my big front AC unit going again.
So I pulled it, got the control panel open and didn't see anything obvious. Then I put it back together, after a little blow to dust and some vacuuming in the chassis.
Then I plugged it in before putting it back in the wall and lo, the fan worked. So I turned it off, shoved it back in the wall and tried the cooling and it seemed to kick in. But then it seemed to short out, although the fan kept working. I'll try it again later, but I noticed that when I plugged it in, there was sort of a crackle across the coils - which I don't think should happen when you plug in an air conditioner that is turned off.
I'm wondering if there is a problem with the house wiring - it's just two wires in metal raceway to the receptacle (it was added on at some point, probably the 70's). The surface mounted wall box was loose, so I turned off power and tightened it, thinking the ground might be loose - however, I don't think that it should need to be grounded (not that I don't need grounding, but that if it's working correctly it won't be shorting) when it's running correctly.
I'll try it once more, but I'm not sure it's worth repairing if there is a weird short somewhere. There are slightly smaller output units that will fit in the sleeve - similar output units are slightly larger and would need a bigger sleeve and my walls are masonry - hassle!
So any advice oh great sages of vintage air conditioning?
