Vintage Air Conditioners. The Holy Grail of vintage appliances?
true about some of the older A/Cs using quite a bit of power-a big 1958 era GE
i have(forget the BTU rating,but it's 18,000 IIRC)pulls about 12a at 230v-it has
a huge 4pole 1725 rpm compressor and the fan motor is a shaded pole type located
in the inside return air stream,adding it's heat to the cooling load..
For garage cooling,i don't use it that often but it is a real treat to run-just
blasts out super-cooled air and runs with such ease and non-chalance,it's very '50s
my newer A/Cs in general use seem to be much more efficient-77westy,'84 WP,92 WP
'98 fedders.
As far as alternative refrigerants go,i know propane is often used in car A/C
systems that originally used R12-it is said to work great,but there are some
hazards regarding the flammabilty of propane LOL.
I used to have people bring me several A/Cs a year for repair,but since around
2000 when the cheapo korean,then chinese A/Cs started really flooding in,
most people won't spend more than $100 to fix a real one-they just head for
walmart...
Just a smidge of propane is used in an automotive R12 replacement product called by the trade name of "Freeze 12." It's mostly just R134a though. I've used it before, and it cools/performs just fine....but I also get good results when converting an R12 system over to straight R134a.
Hopefully I'll come across one of the cool looking 50's era window a/c units one of these days. I'd be fun to have one.
Window Mounting Frame
I have no idea why this system got tossed aside.
It really is very clever and can hold quite a bit of weight. This mounting frame was used for the 6,500 BTU through the 18,000 BTU series. No Brackets or supports to screw into the side of the house.
Old Window AC units is a regional thing
In less corrosive areas collecting/using an old AC window unit makes more sense:
In the deep south an AC unit can see a lot of usage and humidity compared to say a Coastal California city.
A friend in Camarillo Calif had a early 1970's window AC unit he placed in a window only for the summer time, its usage was little thus the cost of operating not so bad.
Here in the deep south in my House still being rebuilt due to Katrina; my big 5 ton AC unit needs major repairs, thus I have several 10+ EER little 5500 BTUH units to "get by". Running one "little guy" wide open drops the humidity down in major way. Running 3 wide open is not enough on a hot day. One unit running wide open probably sees more hours here than a dryer/cooler area.
As far as how long a new AC unit lasts;
(1) a post Katrina fall 2005 GE 5500BTUH unit made in China lasted 2 years before fatigue failure and low gas.
(2) a post Katrina fall 2005 Maytag 5500BTUH unit made overeseas lasted 2 years before fatigue failure and low gas.
(3) a pre Katrina Whirlpool 5400 BTUH as "spare AC" installed in the Fall of 2005 still runs well, it is made in the USA but has an LG compressor.
(4) a pre Katrina Sears/Whirlpool 5200 BTUH unit installed in 1997 lasted until 2007 before replacement. The inner bushing on the fan would lock up, to oil it required removing it from the window, taking the whole unit apart. this was livable until a reoil would only last 3 weeks, the bushing was worn. One had all these crumbling styrofoam pieces. The outside aluminum fins were 1/2 gone due to salt air. An exact fit fan motor was over 100 bucks; thus the unit got scrapped.
(5) a Zenith (rebranded LG ) AC unit was bought in 2007 to replace (4); it works well and time will tell how long it lasts.
(6) A Sears (whirlpool) 8000 BTUH 9.7 EER AC unit I got in 1994 works well in a barn I have away from this area. It sees little usage; it has no corrosion issues. It has a chance of lasting decades. Its bearings are also easy to oil
(7) a AC unit is my business's shed is only used a few times a year. It is a late 1970's window AC 6000 BTUH unit with woodgrain. Its EER is about 6. Its usage is so low that replacement has no return. It has to have its fan oiled every few years, but is old school and the motors bearings are easy to get to.
As far as repairs; nobody locally can fix a window unit with low gas and it make any sense money wise.
With my businesses one window unit used for peak times; repairing the whirlpool box that has a 18,000 to 21,000 size was tried, and one spent more cost than a new AC unit. Thus with this unit one got use to buying one every 3 to 4 years; disposables. Even if one has the older unit "fixed" after years; the fins are usually a mess and disposible.
The super thin aluminum and salt air and high humidity makes for massive corrosion. The newer units that "splash back" condensed water on the outside coil seem to corrode way faster here. It is not just the repair cost here; it is fixing a unit that is degraded with missing fin area.
In the long term running a window ac unit is expensive compared to central air; and running a degraded one is worse. The degraded units just run more; put out less cooling and draw the same power.
Running a brand new 5500 BTUH window unit here wide open in the summer will use in 2 months the same cost in electricity as the units cost. ie one burns 100 bucks of electricity in 2 months with a 100 buck ac unit. With a unit low on gas or with degraded fins that are mostly gone, you still burn through 100 bucks worth of elecricity here in two months; but get 1/2 the cooling. A brand new unit recovers its cost in 1/2 year.
Running an old window AC unit here with an EER of 6 is like driving a car that gets 6 miles per gallon, maybe ok for "crusin the coast" with an old 1950's hot rod car, less practical on a daily basis.
In many window AC units here that I have removed for cleaning, the newer ones seem to be more disposable. ie thinner aluminum fins, water splash design for higher EER, GLUED IN STYROFOAM, pressed in pieces, riveted parts, inner bearing not easy to get to at all. A typical "failure mode" is the inner bearing has water enter; the steel shaft rusts and now it has little clearance in the brass bushing. One can spend 1 hour in time to take the whole unit apart to polish the shaft. Then one has to glue the broken styrofoam pieces; bolt the ground off riveted pieces. An older unit often was built with more fan area and non spashing and thicker fins and easy access to oil the fan motor.
http://www.cruisinthecoast.com/
i have had to junk only 2 of my personal A/Cs over the years;
'86 airtemp(fedders)7500 btu;rubber damper pad on pipe to compressor came
off and let pipe vibrate and crack-refrigerant hissed out,unit sounded
"funny"running and wouldn't cool...
'72 coldspot 5000 btu;compressor seized-fan motor then went into a '79
coronado 5000 btu,my garage workroom A/C.
No real corrosion problems in my area,so still quite a few decades old
A/Cs still on the job around here...
Then the 1957 Coldspot "Slenderette" model. Not currently installed but I crank it up periodically the keep the juices flowing and keep looking for the opportunity to put it to use somewhere.
OMG
The GE A/C
We had a 15,000 BTU in our living room in NJ. Spine Fin Coil, Quiet for that era, Very Low air flow but would cool that house from 90 degrees on a hot day down to 68 in about 2.5 hours.
Unbelievable Just Love the Old Days. And... Made right here in the USA when everyone had jobs. (Sigh)
One issue is fixing up an older AC as a sense of history, another is actually using them all the time in a hot area of the country and going broke.
The EER rating on a unit that is more than 25 years old was often not the greatest.
The up side is an older AC often is easier to work on, its fan motor often has oiling ports.
A 1960's AC window unit in a little house I rented in the 1970's had an EER of about 4.5, but the electric rate was just 2.2 cents per KWhour thus not an issue.
If I had that same AC today and ran it the cost would be double. Thus if one uses it intermittantly and burned 10 bucks, it would be only 5 with a modern AC.
If one used it all the time one might spend 150 per month versus just 75 with a modern AC, thus the old AC would be more noticeable.
In a AC course I took in school back in the 1970's, the window AC units data had BTUH/watts with numbers in the 3 to 8 region, with many units in the 6 range. Here I still have a some units in the EER in the 3 to 6 region, they often are just too expensive to run anymore.
Vintage Packard Bell A/C
This unit sat unused for over 40 years in an unused cabin with the exposed end in a covered porch.
Very simple design.
I would turn it on once every few years till we sold the property.
Still works like new.
The Fox Theatre in Atlanta, GA.
The Fox still runs it's 1946 Carrier AC system. It's a massive and VERY effective system. The intake IS the basement beneath the auditorium. The intake air passes through a water shower and then through the evaporator coils. It's a fascinating system and I was privileged to see it from inside and out while it was running. Surprisingly, it's efficiency is actually pretty good.
I love this old technology, it's just overflowing with innovation unlike anything else seen today,
Dave
Awesome AC Units!
You guys have incredible units! (wink)
I love the GE and the Coldspot! There was a home I lived in as a child that had a similar GE to the one above. It was a little bigger. Dark brown front and the discharge vents were about the same. Outside the fan was exposed in the front. I loved that. I agree. It was a very cold AC. I have passed several homes here in Atlanta that still have these GE AC's running during the summer. They were built to last.
I would love to experience the Coldspot. Looks like it means business. I bet is sounds great! Was the Coldspot built by Whirlpool?
About the Fox Atlanta Carrier System. It is awesome!
If you go there in 95 degree temps to watch a performance, you can feel it working. It is like a cold fog. Wonderful and I agree very effective.
Brent
Are you sure it's *WHOM*? That is an indirect object pro
Speaking of large, powerful impressive units........
What is that long pink tubluar latex cellopahne-wrapped item under the 1957 Coldspot "Slenderette" model?
Er uh uhm.. I meant to say actually, my parents had a 1974/1975 Sears Coldspot 23,000 BTU/h through-the wall air-condtioner. It was capable of cooling 6 rooms. It had an EER of 6.0. Today, Energy Efficiency Ratios of 10 to 12 BTUs (moved) per watt is more the norm.
23,000 BTUs @ 6 BTUs per watt means it drew 3,833 watts. At 220v it used 17.42 amps. 16 amps maximum(80%) are allowed on a 20a circuit. This beast required a 220v 30a circut and had a huge plug the size [and configuration] of an (American) electric dryer's.
It should be noted BTW that the power draw of an air-conditiner varies somewhat based on the temperature of the condenser. (Read: the temp. of OUTDOOR air drawn over it to cool it and take away the heat pulled out of the (air-conditoned) home/room.
EERs are sort of misleading. Older units had smaller coils and I do believe dehumdified better because the evaporator(inside coil) got much colder. So in terms of measuring the work done per watt, moving heat is only part of the story, I'd say. One must consider the dehumdiifcation as well
This unit had a fresh-air intake and a stale-air exhaust. The bad thing about using a stale-air exhaust as part of an air-conditioner is that air one has just paid to cool and dehumidiy is what the air-conditioner is pushing out of the house/room.
Dave-
It sounds like that Fox uses the same swamp cooler system our Fox uses. It is a sight to see, those huge paddles stirring all that water around. On a side note; there is a HUGE central vac system as well. Those 1920's theaters were state-of-the art, eh?
Toggles!
It's a paint roller, silly man. One would think your mind was not focused on appliances. <insert guffaw>
"through-the wall air-condtioners" that fit in a fra
In "through-the wall air-condtioners" here I use in a building are a whirlpool/sears frame size that is now obsolete.
The box was placed through the wall back in 1993.
Its first unit was 24,000 and an EER of 8.5,
a later unit was 21,000 and an EER of 9.0,
the last two have been 18,000 with an EER of 10.
All have the same frame and pan, the "smaller" BTUH units have a higher EER since the coils are about all the same in size.
The first 24,000 unit ran for 1.5 years before the compressor would short cycle. The compressor was replaced under warranty and it lasted 2 years.
With salt corrosion and the "splashing" used on the higher EER models, the outside fins "go away" with time. Thus after 3 to 5 years the unit's EER is way less and it is cheaper to throw it away.
This unit would be on many hours in the hot summer, I have an electric watthour meter on its plug.
During the summer one month would record say 500 to 1000 Kwhr, ie about 65 to 130 bucks. 100 bucks per month was a good average cost if this unit was run. When the units are real old say 3 to 5 years and the coils all corroded, it basically has a lower EER thus would be running a higher duty cycle.
Thus one would be wasting 50 to 70 bucks more with a ruined (degraded) unit, and thus buying a new one at Lowes for 300 to 450 was done, and the energy hog shot and buried. The math was not complex, one would wait for a super sale and swap out the unit and one got way more cooling and a lower KWHR's used. The payback would be one hot seasons usage.
Today I use a mini split AC, the old window unit is only for peaks on rare occasions. It got to where the "through-the wall" form factor on mine was dropped, and the old one I built into a wall. To get a working new AC required buying a new old stock AC unit on ebay.
Repairing a window AC unit that here is old and corroded would be like reusing used toilet paper, or fixing old windex squirt bottles, or having somebody rebuild ones old CFL bulbs, or reusing a 20 to 40 year old water heater. Even a pulled 18,000 EER 10 window unit that is just 2 years old and clean up low on gas and delivered to a AC repair place is an unwanted "thing" that few will want to mess with. My own experience is that these AC's are disposable. v
Frigidaire!
Early last summer I was over at my parents, helping them with a bathroom remodel. My father asked if I'd help the little old lady across the street by removing her old air conditioner from her home.
I walked into the house to see this fantastic 1970 GM Frigidaire 19,000 BTU (20A 240v) beast! To say it keeps my main floor cool is an understatement.
Don't let the new models fool you....the Higher EER's is supposed to be more energy efficient....what it really means is similar to many new washers, the cooling is dubbed down....you select ice cold, and only get moderate coolness....the new machines aren't built better, just dubbed down to give you the idea that its built energy efficient, and alls the manufacturers did was not allow you to turn the thermostat down to a cooler setting.....
the older machines do give you better cooling, in any event, true coolness for energy used as YOU select, not the manufacturer......
not sure about the newer units made today......but on my 1980's kenmores, I can open the control panel up, and with an allen wrench, adjust the thermostat to give me a cooler setting, and it does not run as long.......
At Mom's house I have a 30,000BTU unit, cools the entire house, only runs for a few minutes every hour, in auto setting, this unit is very loud, but better to run for a few loud minutes than having several 5000 to 7000 BTU units in every room running all the time.......my electric bill is never over 80.00 in the summer months.....
Interesting concept
So are you saying a 10,000btu "modern EER" type unit is not producing 10,000btu? Or are you saying; it's still a 10,000btu unit, but it doesn't blow as cold, so it runs-and-runs-and-runs in order produce that 10k, where an old unit would only have to run very little in order to produce the same amount of cooling?
I feel similarly about our 1952 Philco refrigerator. It hardly ever runs, and prior to my vintage 70 gallon aquarium being part of our electricity consumption, our electric bill was rock solid at about $48/mo for a 1,200sq.ft. victorian....and that electric load includes the 1959 Kitchen Aid KD-12 dishwasher, and the 1953 Westinghouse front loaders w/ 220v dryer.
I'll be interested to see what the bill does now that I've added a 1957ish GE undercabinet freezer to the daily consumption.
I DONT!!
Buy into the notion that the old AC s are energy hogs, you get what you pay for, ice cold air is worth more than something running all the time and doing a marginal job, the old ones, like old refrigerators are quieter colder and last much longer, to my mind there is no comparison.
Remember that air conditioners don't so much make cold ... they move heat, from one place to another (inside the house to outside).  The BTU rating of an air conditioner is the amount of heat it moves in an hour.  BTU/HR.  An "old" and a "new" unit (both being in new condition of course) both rated at 10,000 BTU should produce the same amount of cooling ... unless the manufacturer is outright fibbing on the capacity.
Higher airflow rate through the evaporator coil reduces the amount of moisture that is condensed out of the air, related to latent heat content.  Lower airflow condenses more moisture.  I've noticed there's less difference between higher and lower fan speeds on newer units.
BTU is a unit of heat, the amount of heat required raise (or lower, I suppose) the temperature of 1 pound of (liquid) water by 1°F at 1 atmosphere pressure.  A "ton" of cooling is 12,000 BTU/hr, approximately equal to one short ton (2,000 pounds) of ice melting over 24 hrs.
This is where it paid to date someone in the A/C field........
10,000BTU is still 10,000BTU.......but allowing you to use its full potential is what energy saving is all about......
lets take a easier step to understand....central air is controlled by a numbered thermostat.....you would normally have it at 72 degrees...but to save energy you could turn it up to 74 degrees....not so much colder, but you save energy by raising the temp......on a window unit, all you mostly get is a number of 1 to 10, 10 being coldest, now the manufacturers, from behind the control panel, have raised the lowest temp available to only about the number 8, even though you selected 10, air is cool and comfortable, but you may want it a bit colder, now you have run out of selection, and the compressor won't come on until the room warms up.....but from behind the control panel is the thermostat, with a little screw, that can make that machine cool the room to a lower temp......and now you have complete control of how much energy it uses, and how cold you want the room to be......
think of this adjustment that we do to many washing machines water level....the manufacturer didn't make the machine use less energy, all they did was dub down the hot water mixture, and lower the water level....like having a super capacity machine, that only allows you to wash 3/4 size of a load, raising the water level allows you control of washing a full machines potential load.....look at the new Speed Queen TL, 3.3 cu ft tub, but from the manufacturers set water level, you cannot wash a 3.3 cu ft load.....more like 2.5....but theres potential to raise the water level and achieve a 3.3 cu ft load washed effectively....
I have a feeling you guys need to see a pic of a thermostat of one of my machines....I have 2 newer A/C's that now cool the rooms as effectively as the machines they replaced from the 70's...at first they did not...
