Vintage Finds Online: Electronics Part Two:
Ultramatic
Sep 28, 2011
40,873
New York City
Vintage Televisions, Phonographs, Radios, Consoles, Reel to Reel, Stereo Components, Telephones and the like for sale online. I will keep the postings to one hundred or so before I start another part. And of course, everyone is welcomed to post and comment.
Enjoy!
<strong>Vintage Finds Online: Electronics Part One</strong>
<strong><strong><strong>http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?53793__0#start_53793.775083</strong></strong></strong>
1967 MAGNAVOX MICROPHONIC CONSOLE STEREO
<img title="image 8" alt="image 8" />
<img title="image 9" alt="image 9" />
<img title="image 10" alt="image 10" />
<img title="image 11" alt="image 11" />
<img title="image 12" alt="image 12" />
reply#1
Microphonic - means, according to the dictionary of audio and video misunderstood words:
"Diminutive in appearance, but grand sounding like a full orchestra".
It has the resonator tonator built into the tubes, that give the rich, microphonic sound."
nice unit otherwise
microphonic...
also refers to a sonic resonance by vacuum tubes that results in feedback-like distortion, a characteristic most undesirable in tubes used for sound reproduction. Small signal dual triode preamp tubes such as 12ax7/12au7 etc are often checked for microphonic tendancies by the more knowledgeable tube dealers & re-sellers, and some otherwise perfectly functioning tubes can exhibit pronounced microphony. Given some of the crazy prices some of those tubes bring, they should indeed be weeded out for applications where it could cause a problem. Odd that a console mfr. would adopt this particular descriptive term for their product.
Microphonic stages-the high gain stages like for TT preamps,mic preamp,tape heads where you need high gain the microphonics are more of a problem.For high level and low gain stages-not an issue.Some solid state devices can be microphonic,too-Varicap diodes in some FM transmitter exciters-these had to be mounted in a foam insulated drawer and temp controlled so it won't drift in frequency.And in solid state high gain stages-carbon resistors in them can react like carbon microphones making the stage microphonic.So film resistors are used instead.And of course in something like a hi-fi console where the amps and speakers,TT in same cabinet microphonics can be a big problem.Turntables have to be well suspended and insulated-and not mounted above a speaker.Folks are so startled when I show them the microphonic SS stages--esp that FM exciter-you tap it--and you get a loud "SpronnnnGGGG" from the receiver or monitor speaker-and if the transmitter is on air-will be heard over any radio receiving that station.With newer FM exciters and transmitters this is no longer a problem.And some AM tranmsitter oscillator stage tubes can be a problem-since this is a low level stage in the transmitter-if you tap the tube while the transmtter is on-you will get overload trips from the higher power stages.This even happens at where I work-the low level modulator stage preamp tubes 5879--tap or bump these while on air and you get multiple modulator overloads.I have seen so many 5879 tubes it isn't funny in broadcast gear-favorite tube in older Gates consoles for mic and TT preamps.Line amps in these use them,too.And of course these show up in hi-fi stuff,as well.
Oh yes,with those older SS FM exciters they had to be mounted in a separate rack from the transmitter RF power amps-the blowers in these will raise havoc!!!
I like this Motorola Console
I'm just a nut for well-done contemporary cabinets. This appears to be one of those "center third channel" stereos. I would venture to say it probably has Motorola's Vibrasonic system. Could be a Drexel cabinet too. I'm skeptical of the seller's claim that it needs new speakers. There's probably no sound which could be and easy fix, maybe not.
You can tell finished wood from vinyl-covered particle board from a mile away.
Late to the party here but that Magnavox is most definitely solid state, no tubes. I think the seller got microphonic confuse with Micromatic, the style of record player it uses.
Also, Magnavox SS stereos were called Astro Sonic.
The odd television in reply No. 12 is probably a Sylouette
Sylvania came out with a line of televisions where the picture tube face was surrounded by a bezel that stood well forward of the cabinet, whose face was finished in a nubby 60's fabric. The idea was to make the screen seem larger and float detached in space.
There were several variations in this style from "forward-looking" to "aggressively modern".
I am seriously irked that I only found this today... I was in Philadelphia yesterday and would have considered swinging by Ohio for a pick up. I've been aware of this line for years, but this is the first I've seen for sale. My only consolation is that I'd prefer one of the more modern styling. Many mid-century designs are half-&-half and come across as wishy-washy.
