WOOOOO HOOOOOO!!!
i'm soooo happy that you finally got them home!!! and i can't believe how you got them so clean & sparkly!!! the chrome trim looks really good on the control panels, no pitting at all, that i can see!!!
THEY LOOK GREAT!!!
as for how to remove the agitator, your going to have to reach down into the washtub and grab the agitator by the bottom, with your fingers going underneath the agitator. once you've got a good hold of the bottom of the agitator, give it a strong pull straight up. now, becareful that you don't hit yourself with the top of the agitator when your pulling up on it.
if it doesn't pop up & off easily, you may need to fill the washer with boiling water like i had to. and let it agitate with the HOT water for about 10 or 20 minutes. then, you drain the HOT water out and once the washer is empty, reach down into the washtub and grab hold of the agitator again, with your fingers under the bottom of the agitator and pull up.
keep us updated so that i/we can share in your excitement & enjoyment of your new vintage 806 washer & 808 dryer!!!
again, CONGRATULATIONS & WOOOOO HOOOOOOO!!!!!!!!!!!!!!
;oD
