Vintage Mechanics Hand Soap recipe
stan
Oct 20, 2010
2,083
Napa CA
This recipe has hung on the one beams in the basement of my house..I’m guess over 80 years..based on my knowledge of the history.
Over the years, I’ve watched the paper slowly deteriorate.
I’ve thought about cutting the recipe in half and trying it out.
Thought I’d share it here.
Well here’s mine at work:
I have to scrape the pulp off and decide if it’s edible or mostly rinse it off down the drain…
The spout flips up while I squeeze so if the juicer shakes away from the cup or glass the juice won’t spill everywhere and pour it completely out of the hopper after the citrus fruit is completely squeezed…
— Dave[this post was last edited: 7/4/2023-06:02]
This vintage recipe for mechanics hand soap contains 3 gals of water, 1.5 lbs of soap, 4 lbs of sal soda and 2 cups of olive oil.  So the addition of 1/4 cup of kerosene and 1/4 cup of ammonia would be diluted to such a degree that its doubtful that this homemade hand soap would be harmful to either the human skin or plumbing.
 Who knows what could have been contained in commercially available mechanics hand soaps of years gone by or even today for that matter, but I imagine that were we to know the ingredients of these products they are probably similar to this home made recipe.
The inclusion of the kerosene and ammonia would be as a grease cutter so that greasy hands could be cleaned quickly, thereby requiring very little time that this hand soap would be in contact with the skin, causing little if any harm or danger to health and safety.
Eddie
Many people use ammonia in far higher concentrations than this hand soap doing laundry and housecleaning and have their hands in the washing and cleaning solutions.
 Most hair coloring and hair lightening products have a much higher concentration of ammonia, ditto for permanent wave solutions.  And I know this from my time as a licensed Cosmetologist.  Stan, the OP can back me up on this as he’s a Cosmetologist too.
In years past kerosene was used full strength to kill head lice, not something that I’d recommend, but the people that received this treatment all lived to tell about it, provided they stayed away from open flames.
The dilute concentration of both the ammonia and the kerosene in this recipe are minuscule, and would be barely detectable.  People use Fels Naphtha for stain removal and doing laundry and Naphtha is a petroleum distillate just like kerosene.
Both ammonia and kerosene have been used for centuries and probably are less harmful than many modern day chemicals in cosmetics, soaps and detergents.
I would agree that the use of either straight ammonia or kerosene on the skin, or pouring either if these down the sewer would be harmful and not advisable.  But in the amounts used in this recipe for hand soap innocuous.
Eddie
4 Tablespoons of kerosene diluted in 4 gallons (24 quarts) of water makes for a near nil dilution rate. While yes, kerosene isn't best thing for coming into contact with skin one has to consider other factors such as percent in product used, contact time and frequency. Ditto applies to ammonia listed in above formula.
Liquid ammonia is nothing more than ammonium hydroxide and alkaline gas suspended in water. In common with other gases AH doesn't like being mixed with water and thus liberates itself into air. This occurs at a fairly predictable rate (if one wants to sit and do the maths), but also explains why all products containing liquid ammonia have a whiff. That smell is ammonium hydroxide gas liberating itself from water and evaporating into air.
Without a way to bind said ammonia into soap or whatever else after sitting on shelf exposed to air content will decrease.
Above being said once oil was discovered and refineries "invented" clever heads began coming up with all sorts of uses for petrol besides powering motors.
Kerosene back in day was far more commonly found in all households once "oil lamps" began to replace candles. Previously things such as whale oil were used but that all pretty much ended with discovery of petrol (oil).
Even after electricity came about not all homes or areas were wired thus those in rural places still used kerosene lamps. Since the stuff was in homes regardless all sorts of used were found; this ranged from cleaning to liniments and so forth.
Old laundry manuals for housewives, laundresses, housekeepers and others recommended adding kerosene (or worse gasoline) to wash water used for boiling laundry. One can only imagine how many horrible fires, burns and deaths were caused by this advise. Even when such things were avoided one still was left with how to get whiff of petrol out of washing.
As one has stated kerosene was and still is used in preparation of certain soaps.
Science behind things are rather simple; soap emulsifies hydrocarbons forming an (somewhat unstable) emulsion when agitated.
If liquid is left on it's own long enough the two substances will eventually separate from each other. However there are ways around this apparently.
https://www2.chem.wisc.edu/deptfile...e and water are,The emulsion separates slowly.
https://www.google.com/search?q=ker...zCHAQrQIoA3oECBcQBA&biw=1041&bih=730&dpr=1.23
https://www.google.com/books/editio...=kerosene+soap&pg=RA7-PA8&printsec=frontcover
Along same lines famous Fels-Naphtha soap replaced kerosene with another hydrocarbon, naphtha.
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?93762__0#start_93762.1184194
https://en.wikipedia.org/wiki/Naphtha
