Speed Queen TC5 Anniversary and sudsing issue.
This is a problem that sometimes defies a solution, just clamp the hose into the standpipe. I had to do this 30 years ago on my GE combo that’s in my kitchen.
If you use a drain line check valve you will not have problems with water, either siphoning out of the machine or sucking back from the drainage system When the machine is agitating in the pumps running in the reverse direction.
    1.8 MB
Ok, I now understand what you meant by extension hose, and I saw the SQ webpage that you linked to Why I doubt it is the corrugations , but as I read SQ TC5 has too fast a discharge...query SQ if the rubber has also an extension you can adapt to. Thanks for the link.
It may not be the corrugations, I was theorizing that it causes more turbulence than a smooth hose would. I know the pump is strong, but by the time it suds, the water is done, you can hear it just pumping air (and suds on rare occasions).
As far as adapters, all you would really need is a plug with a bigger hole. But since I also have HVAC and water softener in the same drain, the plug just won't work.
    30 KB
Against code, no air gap. And where would I put the HVAC and softener drain hoses? I think we discussed this before.
https://codes.iccsafe.org/s/MIPC201...18P2-Ch04-Sec406.2#MIPC2018P2_Ch08_Sec802.4.3
That looks like a dishwasher drain under a sink?
two traps in a row is against code.
Noted. I suggested it differently the second time. (Not in a row.) Each standpipe has it's own trap to the main line. One would have to come away from the wall in a 3D manor with the T for the trap on the first stand pipe and then just extend the other to the left. Yeah, not a lot of room to work with.
From the picture: is there room to put a coupler here if this one is cut off? The last repair didn't leave you much to work with.
I wonder if a Studor vent, air admittance valve, would help the code concern with this? Although there is one installed in the OP's setup already that explains the different color new pipe section. It's on the wrong side of the trap for what I am suggesting for using your idea.
Here's a closeup. There's about one inch. But another stand pipe won't help anyways, because the hose will not fit in the plug, I've tried to explain that many times, even gave links above to the extension kit.
And that wasn't a repair, there was about 2.5" of pipe between the original fittings. I cut it in the middle, and added the AAV (Air admittance valve or studor). As you can see, that left less that 1/8" on each side. No pipe was removed. You can see missing paint on the wall where the stand pipe used to sit, left of the hot water pipe. There never was much pipe, it's just for the washer and kitchen sink. Sorry for the long explanation, trying to make it clear.
I think I see what you mean about the T, but you can't use a T on a drain, and one outlet would point at the wall if I understand you right. Even if a T and trap would fit (it won't, it's about 1.5" from the wall), when the water is draining, it would go straight through the T to the other trap, it's not going to turn, path of least resistance. You'd need something like a wye, and even then I've never seen that done, not sure it would work.
The AAV will not help with a "direct" connection, it's not an air gap, and it HAS to be installed after the trap. And direct connections are against code. That ain't happening.
    229.3 KB
Suds backing out of the standpipe
Hi William, this is a very common problem. It’s compounded by the fact you have soft water but spin drain Speed Queen’s have had this problem for a long time.
You can let it dump into a laundry tub instead and just let the suds dissipate and go down the drain or you can plum it directly into the drain pipe and put a anti-siphon check valve in the drain hose at the top so it doesn’t suck dirty water back out of the drain system.
This is another reason why I wish they would go to a neutral drain and put an electric pump in this machine. We never have this problem with the TR machines.
John L
The suds is being created by the pump impeller whipping the water and sending the suds up the drain hose. To stop this just make sure the drain hose goes down enough to make a water trap in the drain hose and that will prevent the suds bubbles from getting past.
My TC5 just started this too. As an experiment, I washed a load of towels with just water and no soap at all. I still got suds at the end with the final spin. Weird.
I wonder if my towels have a build-up of soap in them from prior washes that was not rinsed properly.
Regular clothes don't do it, just towels.
I agree, I think those are my second favorite non SQ branded models (the first being GE) but for certain I would've bought one over a SQ because they were way cheaper from what I've read. I've also read somewhere that it was Amana who designed those classic agitators for Raytheon and Alliance still uses them today.
