Hi all,
The internet is a great place since where else could I pose a question about a 20 year old washer!
I love my 20 year old Miele W1070 washer (same as the W1065 but without the (coveted) port hole). Yes it uses way too much water for our sensitive water conservationist ways that we have today, but it goes to 95C (like '11' on an amplifier for all the Spinal Tap fans out there) and is rock-solid doing multiple loads a day (small kids with bladder issues).
Last year I had to tear it apart (not so difficult) to replace the rubber seal (you need a 12" flat screwdriver!), but other than that, no issues.
Until last week, when I tried to take a shower. To my surprise, there was little hot water. That has never happened before, but I guessed it was due to having done a dishwasher load (in a Miele Diamante G2150 naturally) and a 'hots' load at the same time. Later on when I was doing another load I noticed an odd sound. As you AGers know, the sounds coming from your washer are odd, but over time you get to know them and understand where in the cycle you are. This time, I heard a weird sound. When I checked out the washer I found out that it was purging water in small bursts, but continuously. Then I noticed that the hot water was filling... in the spin cycle? When I turned the power off, the hot water continued to flow... all .. the .. time, even when the power was off, or the door open (see below). I eventually had to turn the hot water tap off. I can still do loads but strictly cold water.
To those of you who repair washers, the fix is obvious. But for a novice like me, what is it? Stuck hot water value? Is this expensive? Can I fix it? I have a pretty good relationship with Miele Canada, so I might be able to get the part. But I don't want to buy a new one ... although that honeycomb drum is sweet!
sudsmaster and Launderess, are you listening?
