jeb
water shut off.
Hello Jerry. I had the same trouble with an older Westinghouse water value. I took it out of the machine, filled it with PB Blaster and let it set overnight, then made an electric cord with wire connectors on it and hooked it to the valve. I plugged it into a surge protector and cycled it on and off several times. The valve began to work normally and I didn't have to tear it apart or spend money on a replacement. This was very easy and quick. Jeff
