W Laundromat Video!
water shut off.
Hello Jerry. I had the same trouble with an older Westinghouse water value. I took it out of the machine, filled it with PB Blaster and let it set overnight, then made an electric cord with wire connectors on it and hooked it to the valve. I plugged it into a surge protector and cycled it on and off several times. The valve began to work normally and I didn't have to tear it apart or spend money on a replacement. This was very easy and quick. Jeff
Over Filling WH Washer
Hi Jerry, in reply #14 you said that the machine does not fill when shut off and then you said it did keep filling when shut off.
Try unplugging the machine, if it keep filling the valve is bad, which I dough since I rebuilt it a month ago, any way let us know what you find out.
Water Fill Test
Here are the results from today's test:
Faucet on, Machine off = Fill
Faucet on, Machine on = Fill
Let tub fill to bottom of door opening, disconnect air dome hose from pump, blow into it, the water level switch it is attached to makes a click sound, but water still enters the tub
Unplug machine = Still fills.
I checked the wires on the water level switch behind the door and they are hooked up the right way, and checked the water valve wires against the wiring diagram and they are hooked up like so. Ill retry the test tomorrow to see if anything changes and I cleaned out the bleach dispenser today
