3beltwesty
- Joined
- Nov 29, 2010
- Messages
- 1,057
All the washers available here are typically "larger than one needs", thus using a partially filled machine is quite normal.
As far as waste, the typical usa machine is used 2.5 times per week, ie about 130 times per year. If it lasts 5 years, that is 650 washes.
(1) That is what my machine cost in dollars after taxes. Thus if it dies in 5 years, each wash cost 1 dollar per load in wearout.
(2)Water per load costs me about 15 to 20 cents
(3) soap cost about 5 cents
(4) Electricity costs 2 cents for my new LG and about 3 for my old 1976 machine.
One can weight the cost of special ordering a small 24" machine, or using a Haier 21 and using full loads too.
When one has a job and has costs associated with ones times worth, items (2) to (3) are in the noise, and using the machine more really doesnt not matter either.
For my life; having to wait a month to fill a washer would be wastefull.
One could argue that non USA machines like washers or cars are too big too, since not all pack them full, not all seats are full in busses or cars.
In the USA there is an attitude that we should be able to use our tools like the way we want to, without government rules.
Typically a low capacity 27" FL washer than mine at local stores is an even cheaper model. One googles the model numbers and finds a recall or broken spiders in 2 to 3 years. It is hard to say if it would cost me less to have bought the 349 buck FL washer that was 7/10 the size and cost 6/10 last november.
Running the 27" machine here at 1/4 load really only effects the products life; since its run costs are nil. The water + soap + electricity to run it one month is about 2 to 3 dollars. My cellphone costs 30 times this.
Running a washer always full too means the water level is higher, thus the water seal sees more splashing, the bearings see a higher load too.
