Wash-in Line-up..and extending a gas line
safe enough
If done right! Just make sure to join the sections with a black iron or galvanized coupling and use a good pipe joint compound to seal the threads. Test all connections with soapy water from a spray bottle and you should be good to go. Test the connections on the dryers too, before turning them on as well with the soapy water. SAFETY FIRST!
Extending a gas line
I always just used an old garden hose when we tested dryers and ranges, did this for over 20 years.
However I can't recommend this, you can temporally use two flex connectors but it is not code to do so.
We bought a bunch of outdoor gas grill connectors that are around 10 feet long, these have a nice quick-connect coupler that has a shut off valve in it so the gas flow stops when it is disconnected, the only problem with the grill connectors is that they are intended for outdoor use only.
I would need to see your setup behind the machines.....but why not just tap into the existing gas line with a 'T', and add an extra port(s) as needed?
I would have thought of putting the Neptune to the far left, mainly for gas and venting.....but this works too......
or wait until I get there and install a line for you.....
Make it out of iron pipe and permanent.
HD can make pre-cut pieces of pipe. Is this pipe going out to the garage too? I can look at it if you want to. Do you have extra 220 dryer outlets too?
