WASHER MAYTAG A512
yoram
Nov 30, 2013
Hi listers,
We bought our MAYTAG washer Mod. A512 Serie 04 Serial #987052 back in 1989.
Never had a serious technical problem until last week when we called the insurance company where all our electrical appliances are insured, who determined that we must replace the gear for a refurbished gear (there is no stock of new parts for these washers in Israel). The problem is that the insurance company does not cover gears in washers with a load capacity over 10 Kg. In Israel they work only in Kg and not in cubic feet. We claimed that there's no way we can load more than 6 Kg of laundry in our MAYTAG A512. They sent an expert technician who measured the drum's height 38 cm and claimed that our washer is a 10 Kg model, compared to other Maytag washers where the drum height 33 cm can accomodate 8 Kg of laundry.
Some experts said that our washer is a 3.6 cu.ft. and other experts said it's a 2.9 cu.ft.
Is there aby way we can receive a creditable answer explaining what is the load capacity of our washer A512?
If possible I will appreciate receiving also a copy of the A512 brochure and its specs where I can read the manufacturers information in this matter.
Thank you!
Might be 2.9 CF - but no more than that
I know that the last Maytag "Dependable Care" models (through 2006) were rated at 2.9 CF - and were "Large capacity" machines.  As a result, the most that an A512 could be is 2.9 CF because I don't think any of the "true" 1966 - 2006 Maytags were ever bigger than the last "Dependable Care" models.  I am not sure if an A512 was a Standard capacity or a Large Capacity tub.  If an A512 is a Standard Capacity machine, then I'd bet it is more like 2.5 CF.
Andrew S.
[this post was last edited: 11/30/2013-19:01]
Maytag tub size
I'm not sure about your particular model, but my A806 uses 19 gallons of water on a full fill. There are 7.48 gallons of water per cubic foot. 19 divided by 7.48 is 2.54 cubic feet.
I realize that the tub is actually somewhat larger than this, but in a top loader this is the capacity that is actually used.
I hope this helps.
