Washer rebuild
Eugene,
That...was...awesome!!!
As someone with zero mechanical ability, that was beyond amazing.
I loved the addition of the musical score. The tear-down almost sounded sad. Like the machine may have thought it was the end of the road.
Then, the meticulous labor of love on every nut and bolt.
Finally, the glorious and triumphant return to life!
I think I may have teared up just a little.
Man...I wish there weren't so many miles between us.
As the kids say, I'd be all; "Shut up and take my money!"
Not to mention, the fact that you could do it all in less than twenty minutes! 😉
Beautiful work!
Barry [this post was last edited: 4/16/2020-10:35]
Our 1995 Maytag
5 cycle Fabric-Matic was working perfectly still when hubby insisted on replacing it when the vintage 1988 Halo-of-heat gas dryer wore out in 2007. That only happened because we were all working a lot still, and the kids didn't tell me soon enough when it got noisy. The bulkhead sliced deeply into the drum and peforated it.
This is an awesome video I agree. Yes I was also wondering what the noise deadening material is that you put all over the inside of the machine. I would love to get some of that and put in both my washer and dryer. Even though they are both pretty quiet as they are. I would still not complain to add that extra bit of noise deadening to it .
Tchaikovsky's Maytag Symphony in AW major
A first class classical rebuild!
Was wondering if you ever replaced the brake gasket that ripped apart on disassembly. That happened to me and I cut a replacement out of a piece of heavy paper about the same thickness, but haven't put it back together yet.
Looked like you had some trouble getting the tub cover back on. That's why I'm afraid to take mine off to do a thorough rebuild as you did.
That video is really really AWesome, man. Thanks for letting us look over the shoulder of a master at work!!
@hobbyapocalypse
That brake “gasket” is just to isolate noise. As long as it’s there mostly it’s fine. Make sure you grease up the pads if you ended up washing them. I didn’t and the washer started screeching when braking. I rubbed grease on it and it did fine.
I really struggle with the lid. It’s not hard yet for some reason it’s my Achilles heel. It’s just too damn adjustable. I would recommend making some markings so you can set it back the same depth as you removed it. It’s a pretty fun machine to rebuild. Like assembling a tank.
Nicely Done!
Eugene,
I salute you. Longtime fan of your work. Can you comment on the sound deadening material? Automotive? The link isn't working for me. Once again... RESPECT.
Chris
The Wrench!
In case you missed it, the highlight of the video was the wrench (with my name on it).
Kidding aside, this is the best video that I have seen in a long time. Great work!
It sure is easier to put in the washers on the outside of the tub when the cabinet it removed. Even when using rubber cement to hold them in place, it was always a pain to get those bolts to go through the washers and brackets. I'm referring to Blackstones, of course.
I must share this video, to friends who are not members of this club.
