WestingHouse Boot 5303261132
buddy
Jul 16, 2019
Stroud
I have a '94 White WestingHouse(V2) / 27 " LT350RXD1 with a deteriorating boot, Manufacturer Part Number 5303261132 The original boot cannot be located. Can other boots from other models be used? Even with some modification.
Or is there anybody that knows of a possible source. There are almost 90 different models of front loaders that used this part.
This stacked dryer/washer set is an amazing system. I'd hate to abandon it just because of one part.
Buddy
WH FL Washer Door Boot
WH used the same boot since 1959, if you keep searching you will probably find at least a good used one.
If it has a tear or small hole that is causing it to leak the boot can be removed and either patched or even turned up side down and reinstalled and used.
We have lots of other parts for your model washer, this last [ 1989-1994 ]version of this washer was fun but not very reliable.
Westy
That doesn't look so bad and it looks like the boot is good.That is the washer my mother had that started it all for me.I have seen those in far worse shape than that.Do you have the front panel?I have been looking for one of those machines for some time.
quickii, is this part still available, I really could use it badly.
get back when you can.
Thanks. Buddy/Doug
