What a Quandry -Washer Dryer Set
whirlcool
Jun 29, 2005
9,618
Just North Of Houston, Texas
As you know, we have a 93 Whirlpool TOL Electronic Washer & Dryer set.
Recently, I believe the washers transmission is going south on us. It won't operate at low speed at all. It just sits there. Normal agitation speed works, except for the last 6 minutes which is susposed to be slow agitation on Normal wash mode.
So I figured for about $300.00 I could put in a new transmission, pump, coupler and new internal hoses and be good for another 17 years or so. The machine is in excellent cosmetic condition.
Just for the heck of it we stopped by a local appliance store and looked at some washer/dryer sets. Of course the store was stocked to the rafters with LG. But the store also carried Maytag & Whirpool machines. We came across a Samsung WF330ANW washer. It appears to be very sturdy. It has that diamond texture drum. It also has the VRT system. But no steam or silvercare. It has all the cycles we would want. I asked the price, and the salesperson noted that it is $599.00, but I could get it for $569.00 with free delivery & setup. The same price for the dryer too. Hmmm, About $1200.00 for the set.
The question is should we repair our Whirlpool set and keep it or head off for the world of FL bliss? The only considerations I have is that my clothing must be well rinsed (or I itch like hell) and we do wash pet beds with dog hair on them. And we would be washing a queen sized comforter on occasion.
What do you all think we should do? We are deadlocked here on a decision.
WP
IT sounds like your motor isn't running on slow speed. If it's a 2-speed motor, a used one can be had for about 25 bucks and it's super-easy to replace. If the motor is fine and the control system isn't telling it to go to slow speed, than you have a tougher nut to crack.
My vote would be to fix the old set. It will outlast a new one.
Dave
fix it
i would fix the old one-one thing about DDs is they are super
easy to work on and new and used parts are very avalible
-will far outlast import junk.
Besides that's a cool set anyway.
I'd fix the DD and agree 100% with the others' diagnosis. Not the transmission or coupler, though I'd do as you said and replace the pump, hoses, and coupler while in there.
Most parts for DD machines are easy to find. Allen's model is electronic. Check the board as well. That part could be NLA by now.
Melvin:
The washer has two boards in it, the power supply board and the minicomputer board. The boards are available for about $200.00 each.
Someone mentioned to me that there may be an onboard diagnostic that would tell me what board is at fault. Has anyone ever heard of this?
Tomorrow I am going to take the control panel apart and reseat all the connectors on the boards to make sure they have a good connection. Somehow, I think that the control boards are going to be where the problem resides.
BTW, the model number is LA9800Tn1. With the n1 indicating the color, almond.
I was meaning the computer board, but does not hurt to test both. There should be a data sheet or schematic in the console area. Usually they have the key sequences on the data sheets to put it in diagnostic mode, as well as the error codes. We need some pictures of these boards.
relays on the board
the control board will have some relays on it to switch the
motor-the one for the low speed may have burnt contacts,bad
solder joint,etc.
DO IT ONCE, DO IT RIGHT, SPEND YOUR MONEY ON FIXING THE WHIRLPOOL. IF IT BREAKS AGAIN, IT CAN EASILY BE FIXED, THE SAME CANNOT BE SAID FOR THESE NEW PIECE OF !@#$ FRONT LOADERS THE DAM GOVT. IS JAMMING DOWN OUR THROATS. WHEN THE SPIDER BREAKS ON THAT SAMSUNG, AND THE MACHINE SMELLS LIKE MOLD, GUESS WHAT, YOU CAN'T FIX IT, AND THUS IT BECOMES GARBAGE, MORE FILL IN THE JUNKYARD, DOES ANYONE ELSE OUT THERE GET THIS, NOT YOU GUYS, BUT THE ELITIST WHO THINKS THAT SAVING WATER, AND PAYING THESE PRICES FOR JUNK EVERY COUPLE OF YEARS IS OK....SORRY FOR THE RANT, BUT FIX THE WHIRLPOOL, YOU'LL BE GLAD YOU DID.
MIKE
We have been happy with the Whirlpools performance. It really does get the clothes clean.
There are no dents or scratches on the set, the tub is like new so that's why I am considering overhauling it and probably getting another 17 years out of it.
It's not that much of a water hog, the manual states that it is a 29 gallon fill on the default normal mode. And being direct drive most parts will be available for at least the next 50 years.
Try something.
Try running it on a gentile cycle. Slow wash and slow spin. If it does that, then the motor is fine but the control system is acting up. If it does nothing, it could be the control or the motor.
Dave
fix the Whirlpools. They are so cool. Got to see pics too.
An easy way of testing the motor is to switch the wires that go to the slow and fast speed. I believe the slow speed is the orange wire, off the top of my head. Someone else would know more.
Is there somewhere to get the service manual for this washer?
I was amazed to find out that even the wash basket is still available for this machine. The one we have is in great shape. Since this washer/dryer set was always used indoors in an conditioned environment there is no rust anywhere on them.
If you want to see more of this set, click on the link. BTW, the control panels do not look that scratched up in person. The flash picks up everthing!
