The Chinese-made XXL machines were available here at our NE Furniture Mart. Easy enough to spot on the sales floor, they made the real Asko-built units avert their eyes and begin to inch away from their larger cousins by-marriage.
The CU ratings are interesting but, as always, do raise questions about their methods and ideology in testing. Comparing apples to apples is great, but the capacity, drum and load sizes would make "one"
wonder if they were indeed tested on equal footing. Water temps, etc. in a cold-fill machine could differ greatly in the tests. Maybe you could call them and speak to the testing supervisor and report back? LOL I wish! I had great washing results with the Asko I had but I'm sure the water temps I used and what CU used could be quite different!
I would guess L wouldn't stoop to the XXL and is looking at the European models with boil-wash, etc. I've only had one set of Askos, from about 1999-99. I used them as a pair for a few months before giving them to a good friend nearby. Other than replace a broken shock and rewire the cut cord for the dryer, they required no other service for nearly 5 years of constant use. They were replaced with LG's when the washer heater went out, the only flaw in an otherwise working set. I personally did not like the air-flow dryer very much, too small and too loud. If I had room for only that dryer, I would come to terms with it but when I had the set here, I usually bypassed the dryer except for smaller loads.
I like the washer door seal and lack of boot folds on the washer - possible because of the front door-cover and separate door panel behind the machine front. This is, IMO, superior to all other brand's large, folded rubber boots as it gives slightly better access to the drum, no water retention, cleaner, etc. and the solid rubber seal will outlast a moving part many times over. That said, proper care and use will ensure good service from any boot design, as we all know!
I would imagine parts and service for the Asko will be easier to obtain, as mentioned, as the market penetration has been much wider and for a longer period than has Miele in most of the country, though in NYC it's probably a "wash" between Asko and Miele anyway.
